Sponsored by:
Sponsored by: CARiD
Quick question about Canards
Old Aug 25, 2015 | 07:44 AM
kaj's Avatar
kaj
Originally Posted by Johnr352
Any aero, at less than very high speed, is for appearance.
try to tell that to some of those auto-x guys LOL. wings bigger than their cars, i tell ya.
Old Aug 25, 2015 | 12:56 PM
ddawg1130's Avatar
I don't deny that canards will create some downforce (thought very limited) at high speeds due to their design. But I swear there was an amazing article posted on here or one of the other evo forums discussing how canards are used to control airflow in order to increase the effectiveness of other body panels, and that on a proper true race car application that that is the purpose of canards (and not to generate downforce directly).
As for bolts vs rivets, I think the bolts look fine:
Old Aug 25, 2015 | 01:07 PM
kaj's Avatar
kaj
mostly. the splitter handles most of the front downforce. the canards are often used to direct air over/around wheels, down the car towards the wing, etc. usually used to "shape" the air, more than downforce, though they would work if you only needed a bit, i suppose.
i agree with one of the post above: canards/no splitter = not too functional and probably added for looks.
Old Aug 25, 2015 | 04:58 PM
TxFAkuma's Avatar
Originally Posted by kaj
Rivets = no need to remove bumper unless you add washers, which I'd recommend anyway, since you're riveting onto plastic.
Okay so i went to the body shop.. First of all.. they made a good point (i think) and they said the rivets rexpeed provided were "good enough" but they recommend me putting in blind rivets instead since they are bigger and longer and would hold more durable. So i took a look of the difference of the rivets and the blind rivets just has a touch of a bigger rubber base on the outside. So it's not that bad.
Anyway.. they want $120 if they just use the blind rivets and drill it in their and that's it. They want $240 if they have to remove the bumper and drill in the blind rivets and put a washer behind it too hold it in place.
So my question... for APPEARANCE (not sure if it matters) is it worth it too remove the bumper and install the washer behind the rivets? Or should i just go with the blind rivets itself? Will it fall off easily?
Thank You.
Old Aug 25, 2015 | 05:22 PM
kaj's Avatar
kaj
rivets flare out when the ball is pulled towards the surface. the amount and shape kinda varies from rivet to rivet. you can try to just put them right in. if one comes loose, you will see and can redo it. the only downside is it may make the hole mis-shaped from pulling through so the next one may not work at all, without going to a larger one.
taking the bumper off isn't too hard and may save you a lot of trouble in the long run. putting washers on the back side will prevent it from pulling through.
maybe you can mark where you want them with tape, take the bumper off, then have the shop do it? of course, if you go through the trouble of doing that, then you may as well do the rivets yourself. i got a rivet gun and box of rivets from Harbor Freight for about $20.
you drill the hole, put the rivet in the hole, hold the canard against the bumper and squeeze the handle. done. it's really, really easy. on a scale of 1-10, i'd say about a 2 or 3. you should be able to do all this, with washers, while only having to move the fender liner out of the way?
unless you are worried about then not being aligned right.
Old Aug 25, 2015 | 09:35 PM
Johnr352's Avatar
He looks like he is going (relatively) fast.
Old Aug 25, 2015 | 09:55 PM
kaj's Avatar
kaj
Yes, but not usually "very high speed".
Old Aug 26, 2015 | 11:48 AM
hoobastnk90's Avatar
I wouldn't bother with the washers imo I had rivets holding some on my splitter on my s2k and took it on track all the time with no problems. I just combined it with 3m double sided tape for added holding power. The only time I had a problem is when I went off track and the ground helped remove them off my bumper...along with some of the bumper..
Old Aug 26, 2015 | 01:06 PM
TxFAkuma's Avatar
Yeah, i was thinking i could save the time and money by installing the blind rivets and using 3M double Sided tape as well.. Considering you took them on the track and they didn't fall off makes me want to go this route. Installing the washers is safe yes, but i do not have a truck to remove the bumper to carry it with me to the body shop..
Old Aug 26, 2015 | 02:26 PM
kaj's Avatar
kaj
If you plan on using a good 3m tape, you will be fine.
Old Aug 27, 2015 | 08:24 PM
Johnr352's Avatar
Yes, but not usually a "very high speed".
The relationship of wing, to speed, to size of vehicle for which the wing is providing down force is such that the larger surface area of a wing, the less speed is required to produce downforce. S, given its size, a canard needs quite a bit of speed to produce a measurable affect for an Evo.
nonetheless - uncle...
Old Aug 27, 2015 | 10:02 PM
kaj's Avatar
kaj
I know. I was just giving you a hard time; teasing you on your wording. ☺
Xchild4584123
Feb 14, 2014 01:53 AM
FiftyFive
Apr 3, 2008 12:03 PM
bus
11
Dec 17, 2007 12:47 PM
scoob2evo
Aug 15, 2006 08:32 PM
SpnSprt
Apr 26, 2005 12:56 AM
