Sponsored by:
Sponsored by: CARiD
Buying a new MR
Old Sep 8, 2015 | 09:27 AM
Kevin Koszarek's Avatar
Buying a new MR
I am trying to find some information on first steps to take when upgrading. I plan on new intercooler piping and an intake. What else can be done at home that will give me good increased engine horsepower. I want to build correctly from the start and be able to slowly aim for 500HP.
Old Sep 8, 2015 | 01:58 PM
jayt27's Avatar
I would suggest just starting with the basic bolt-ons and guages (intake, turbo back, ic piping, 3 port, boost and afr gauges) and then get open sourced tuned. If your not happy with the power and still want 500hp, at least you'll have the fundamental parts installed.
Old Sep 8, 2015 | 03:22 PM
Dr.Chris's Avatar
And with an MR 500 HP may be a bit steep. The SST can hold up to maybe 340-350 tq at the wheels before new clutches will be needed to hold the power. If 500 is your goal, find a clean used GSR and go from there. No point in buying new if you are going to replace everything anyway. And a tidbit of advice, don't start adding parts without proper tuning. Be ready to at least get an e-tune from a reputable tuner before you even put on an intake. But as suggested above, intake, turbo back exhaust, 3 port boost controller and a tune will get you above 300 to the wheels.
Old Sep 9, 2015 | 06:50 AM
MisterRegato's Avatar
If you keep the tq in check HP wont matter. At that point (500 hp) you're going to need a block built. The SST can handle that but the stock block cannot, or it will be very sketchy.
Old Feb 27, 2016 | 09:13 AM
Mako_7's Avatar
and what are some good open source tunes to go with? Just recently read that AP aren't good for MR's? Forgive my newbieness...
Old Feb 27, 2016 | 10:19 AM
Napalm_Enema's Avatar
You should get in touch with an e-tuner if there isn't anyone in your area that specializes in MR's. Kozmic Motorsports is a great place for MR's. Luckily they are in my town.
Old Feb 27, 2016 | 07:35 PM
MercuryMR's Avatar
Once you get close to 350 WTQ you will need to upgrade your clutch pack it cost's around 2k and you will need to pull or have someone pull your tranny plus ship it to where they do them.If you want more power gains get a GSR the MR you can upgrade it but costwise the GSR is the way to go.I do have a cobb accessport with the AMS STX 300 flash it works ok better than stock but it might have been wiser just to upgrade the Turbo with injectors intake catback etc.The flash only works with a bone stock car.And I do want more power but it aint cheap.
kiraford
May 18, 2018 11:07 PM
DesertDog57
Mar 12, 2018 10:56 AM
LhanaPong
10
Aug 5, 2011 01:37 PM
lagcisco
Mar 26, 2005 02:31 PM
