Paint peel on center hood scoop insert
I ended up just buying a can of black plastidip to fix mine. Much cheaper than buying a carbon fiber replacement, even though I would have preferred that option. Turned out better than I expected and matches the other black vents giving a nice contrast on apex silver.
Captain, if you pull the scoop, you'll see that the under-hood sound deadener/insulation will be exposed. It's probably not the best to drive around with it getting pushed down / stressed or getting soaking wet if it rains. If you take that off as well, I would think you should be ok for a little while.
Xyster the 1st
Evo X How Tos / Installations
Dec 7, 2014 06:25 AM
Xyster the 1st
Dec 6, 2014 11:59 AM
