Sponsored by:
Sponsored by: CARiD
Idles up and down
Old Oct 8, 2015 | 07:26 AM
boyvang's Avatar
Unhappy Idles up and down
First my mods are just ets intake, resonated test pipe and dual catback exhaust with cobb flash to stage 2. Sometimes coming to a stop, rpm idles up and down for like 5 seconds then calms down to normal? Does it got to do something with my mild mods?
Old Oct 8, 2015 | 07:49 AM
evostanman's Avatar
Do you have the intake heat shield installed?
Old Oct 8, 2015 | 08:35 AM
boyvang's Avatar
I do in fact have the era heat shield that came with the intake. Will that matter?
Old Oct 8, 2015 | 09:16 AM
.M.'s Avatar
.M.
Check the connections on the intake and make sure nothing is loose/leaking.
Old Oct 8, 2015 | 09:36 AM
shekaar's Avatar
It's related to intake/heat shield. Mine does it as well with my ETS intake.
Old Oct 8, 2015 | 09:37 AM
haulksmash's Avatar
im having same issue. when i want to coast to stop and put in neutral the rpm bounces- i read that its a issue with the intake reading density vs MAF.
Not sure if thats the fix, been too lazy to get it figured out but let know if you do
Old Oct 8, 2015 | 10:40 AM
evostanman's Avatar
It's normalish to happen... check your connections and all. I have a feeling though that it's the heat shield thing. Mine does it sometimes but it's nothing to stress about.
This will sound silly but... is your a/c on when this happens? I'm sure you know what happens when the a/c is on, right?
Old Oct 9, 2015 | 05:37 AM
boyvang's Avatar
It doesn't really bother me because it doesn't go that high on the rpm, just a few bump up then back to regular. Usually when ac is on rpm goes a little lower.... it does this more often when ac is off as far as I remember.
ShaneS009
Aug 26, 2010 12:49 PM
robogast
15
Aug 6, 2009 05:35 AM
AustinEvo8
38
Dec 26, 2006 01:55 PM
pgmike
Lancer Troubleshooting
Jul 1, 2004 02:30 PM
