Cat Delete concerns
Cat Delete concerns
Just purchased my first EvoX (2013 GSR) used and it came with a cat delete. It really isn't an issue legally in my state but man that smell gets to you when you sit at stop signs/lights. I was wondering how much sound/performance will I really lose if I add a new catalytic converter or if there are alternatives to reducing that smell. This is my first decent car so I want to enjoy it but I also want to take care of it and myself as well
Appreciate any recommendations. Also I haven't gone under the car since I bought it, I've only had it for a day so far I'm not actually sure what model the exhaust system is but it's a full ETS replacement with the delete.
Thanks
Thanks
Your best bet is putting a high flow cat in. I'm sure it will reduce the noise a little, and shouldn't affect the power output too much. I would however recommend getting it retuned since it will change the exhaust flow.
If you plan on running e85 the test pipe won't really be an issue. Seems to me that it doesn't really smell all too bad when on E85 compared to when its on pump. I could be used to it by now though
Originally Posted by e_kobz
I have a test pipe and am currently running 91 pump gas and I cant even notice the smell. You'll be fine OP.
+1, if the smell is really that bad while you're at stop lights, you may want to check under the car for any exhaust leaks. Unless the wind is blowing towards the front of the car, you shouldn't really be smelling it, since the exhaust is there to get it away from the rear of the car.
As far as the OP's question, I did get some smell at lights when I was running 91. With E I can't smell it at all unless I really get on it. The rule is "Performance before comfort & health" So I would say give it time, you will get use to the smell.
My friend ran a high flow cat and to be honest when I was behind him it smelled just as strong as running no cat.
nlp187
Jul 8, 2012 10:32 PM
leetman
11
Dec 1, 2006 08:38 PM
GREDDY
14
Oct 23, 2003 06:54 PM
