Sponsored by:
Sponsored by: CARiD
TWM Shifter Cage rattle
Old Apr 27, 2016 | 09:44 AM
TurboNubCake's Avatar
Gents,
I've installed a shifter cage about a few months ago with no issues until last week. When I'm in high RPM the shifter rattles like there a loose washer somewhere. I've ripped apart the car twice now and tighten everything with no solution. I cannot pin point where the rattle is coming from.
Any idea's?
TWM seems to be a hard company to get a hold of. Anyone have any contacts there that might be able to assist?
Old Apr 27, 2016 | 06:12 PM
UltimatePB's Avatar
Found it... you are not going to want to hear it.... It is the change in your little tray there in front of the shifter.
Old Apr 28, 2016 | 08:35 AM
You know. I thought of that and took it apart and found a quarter. Thought that resolved my issue. But it didn't. I'll look again.
Old May 4, 2016 | 08:16 AM
migs647's Avatar
Have you tried pushing it to the side while in 2nd / 4th (not sure which gear you're in)?
I noticed this on my GSR, and ended up putting zip ties on the lock washers as I noticed there was a decent gap. Once that gap was taunt, the rattle went away.
Old May 9, 2016 | 01:25 PM
I'll check that out
Old May 19, 2016 | 09:53 AM
Resolved the issue. It was the Cable Holders. The came loose from being hand tighten. If you remove the air duct completely, you can then get an allen wrench in there to tighten the cable holders. Now it's as smooth as eggs.
I've install this shifter cage a dozen times. I'm now a pro at it. If you need help. Holla at your boy.
1fastvet
22
May 23, 2016 07:40 PM
MannyEvoX
Feb 10, 2015 10:34 AM
vastevo
Feb 4, 2013 02:56 AM
weap0n
May 17, 2012 02:54 AM
jrecluse
Dec 20, 2010 08:24 PM
