Sponsored by:
Sponsored by: CARiD
Flat towing Evo X MR?
Old Aug 15, 2016 | 07:11 PM
PaVa's Avatar
Made an account just so this can be answered, your help is appreciated.
I can't seem to find the answer after much digging.
Just like the title asks, can I flat tow (all wheels on ground) my MR for a short distance, around 2 miles?
If it can be I am assuming it has to be turned on and in neutral.
Old Aug 15, 2016 | 07:13 PM
Napalm_Enema's Avatar
not even once, no, never.
Flatbed only. Transmission costs around 12k to replace so never risk it ever.
Old Aug 15, 2016 | 07:24 PM
LB_Reddy's Avatar
Airlift truck towing is the correct way to do it.The evo has sst,acd & ayc.cost $$ if damaged
Old Aug 15, 2016 | 08:33 PM
PaVa's Avatar
So what's the difference between flat towing and rolling the car in neutral?
Old Aug 15, 2016 | 09:43 PM
LetsGetThisDone's Avatar
When you're rolling that in neutral it's going about 3mph...
Old Aug 16, 2016 | 03:45 AM
ardevas09's Avatar
and you wouldn't push a car in neutral for two miles...
Old Aug 16, 2016 | 06:23 AM
GTijoejoe's Avatar
ok ok, what about if you coast in neutral at highway speed ?
Old Aug 16, 2016 | 06:48 AM
HatrixMouse's Avatar
This is assuming the car is on, which means the pumps are lubricating, the systems are moving in sync, and everything is functioning the way it should.
When you move these parts while the car is off, bad things happen.
Old Aug 16, 2016 | 06:49 AM
hoobastnk90's Avatar
I mean I cant see why on all four wheels it would be bad, although I would just rather eat the 100 buxs for the tow to be safe, but its your car do what you want and if you think it will work then have it.
Old Aug 16, 2016 | 11:12 AM
russ72's Avatar
I believe it also states that in the owners manual about the proper way of getting it towed.
Old Aug 16, 2016 | 12:14 PM
Veronica's Avatar
What does the Owner's Manual say? (look there first)
Old Aug 16, 2016 | 12:22 PM
RazorLab's Avatar
Not much digging...it states in your owners manual the proper way to tow the car.
https://www.mitsubishicars.com/owners/login
Old Aug 16, 2016 | 01:06 PM
PaVa's Avatar
Idk why you are so quick to bash. The manual does not specify if flat towing should or shouldn't be done. It does state that 2 wheels on the ground shouldn't be done though.
Old Aug 16, 2016 | 01:08 PM
RazorLab's Avatar
My apologies for helping. Good luck!
Old Aug 16, 2016 | 01:47 PM
evostanman's Avatar
You can try flat towing it and letting us know what happened.
