Sponsored by:
Sponsored by: CARiD
fender vents removed.
Old Aug 26, 2016 | 10:22 AM
CaptainCrunch's Avatar
Double sided tape and push in plastic tabs. Not much to it at all.
Old Aug 26, 2016 | 10:58 AM
ChipperEvo's Avatar
but you still have to get inside the fender liner right? Or can you push down on the tabs from the outside?
Old Aug 26, 2016 | 02:29 PM
ddawg1130's Avatar
If you did that would be very easy to do. Fender liner is held in by like 6 push tabs and a bolt and would take 2 minutes to remove enough to reach behind it.
Old Aug 26, 2016 | 02:41 PM
Originally Posted by VDubJCabe
I'm assuming to take them off you have to take out the fender lining and go in that way.
Originally Posted by CaptainCrunch
You don't even have to go through the fender lining. I pulled straight out from the front with no issues.
Originally Posted by ChipperEvo
You just straight pull it out?
Seriously?
Old Aug 26, 2016 | 02:42 PM
I was thinking about cutting out the middle portion of the stock black plastic trim piece, but I'm sure I'd butcher it and have it look like ***.
Old Aug 29, 2016 | 06:21 PM
2015_MR's Avatar
I would be undecided on whether to take them out or not. I like the Carbon Fiber ones better than the factory ones that are painted the same as the car. But the way cars are built these days they are probably held in by plastic push tabs.
Old Aug 29, 2016 | 08:02 PM
moparfan's Avatar
I think the ideal way is to cut out the middle metal portion of the exposed vent.
Old Aug 29, 2016 | 11:07 PM
Daemon671's Avatar
Here's a carbon fiber fender vent.
by Daemon671, on Flickr
Old Aug 31, 2016 | 11:46 AM
ChipperEvo's Avatar
Seriously?
Seriously what? You have 0 detail in that post other than pull it out while many others are saying you have to push in on the tabs some how. that's why I was asking.
Old Aug 31, 2016 | 08:29 PM
From the threads I searched and read, there is no harm in removing them. You don't even have to go through the fender lining. I pulled straight out from the front with no issues.
are there no screws that keep them in place? You just straight pull it out?
Thats why "seriously". Details are that it is held on with double sided tape and plastic tabs and I pulled straight out without going through the wheel well lining. Thats more than 0 detail. Kind of hard to write more detail than that for something so simple.
Old Sep 1, 2016 | 06:24 AM
ChipperEvo's Avatar
again, you say pull it straight out and others are saying you have to go through the liner to push the tabs out. that's why I'm asking. but hey if you want to be a dick instead of just answering more power to you.
Old Sep 1, 2016 | 07:24 AM
itsmyturn's Avatar
Veteran: Army
I just pulled on the vents gently. I did not lift the car up, did not remove the fender lining to get to it. Just pull on the vent slowly and carefully.
Old Sep 1, 2016 | 12:27 PM
lol, a dick? You're sensitive. I'll try to be nicer, sweetheart. I physically removed the vents myself. I did not go through the lining. OK? Great. Good luck buddy!
Old Sep 1, 2016 | 12:29 PM
How do you like the look?
Old Sep 1, 2016 | 12:48 PM
.M.'s Avatar
.M.
Someone needs to do a diy guide with lots and lots and lots and lots of pics
