Sponsored by:
Sponsored by: CARiD
Intake ISSUEs. Turbo spitting/knocking
Old Aug 29, 2016 | 09:52 AM
4G63_EVO's Avatar
Originally Posted by jhkuse
Bad news fellas. I took the intake out and put it all back together, no luck. I'll have to take it in to get it checked out for a boost leak. Looks like something else went wrong that I'm not aware of that has nothing to do with the intake.
The car has been sitting in my garage for a week without me using it during the time the Bung came off of the intake. The garage has been getting extremely hot so idk if that could've loosened some things or caused a leak. I'll get it checked out and update you guys.
Thanks again for all of you who helped me try to figure this out
Have you checked your BOV? I recently saw someone who found his BOV stuck open on his X
Old Aug 29, 2016 | 09:57 AM
jhkuse's Avatar
Originally Posted by ugakirk
Well, something is not right. I seriously think its something that you accidentally unplugged or pulled off during uninstalling/installing the intake.
If you take it somewhere, don't go in to boost. You don't want to damage the turbo..
Yes I had a doubt that I might have missed something too.
But I have done all the bolt ons on my car and I've changed the intake a couple of times al ready so I'm not an expert by any means but I'm sure that all the lines going from the intake are secured correctly.
But thanks man, I'm very confused to what happened there. Yea when I drive her she dives completely normal with no boost so its deff something that cracks/pops off under pressure.
Old Aug 29, 2016 | 10:11 AM
jhkuse's Avatar
Is the small hose on the nipple on the BOV connected both on the BOV side and the wastegate side? Did you possibly unplug one of the lines on the boost solenoid? You didn't install the BOV backwords or something did you??
Yeap, BOV hose is secured properly. I didn't touch the BOV and haven't since I put the AMS intake the first time about a year ago.
My 3port solenoid is secure as well with all the hoses secured and good to go too.
Originally Posted by redlightrunner
is your BPV leaking? the hoses around it rotted or or corroded. did the return hose slip off of the Ic? i had a problem once where a coupler was lose and it was still tight, but not cranked all the way and i couldn't boost. mad scientist is in FL. take it there
All the hoses running from the intake, BOV and Boost control solenoid are new so those are all good.
So initially I though maybe some coupler got loose with the heat and maybe was popping off under pressure but that has happened to me before with an UICP (which some hairspray fixed since) plus that one made a huge popping sound under boost, so very noticeable. The second time it happened to my IC one but again once that one popped off there was a very distinguishable sound of air leaking out.
Also, when air was escaping due to coupler the turbo wasn't spitting and hesitating like its doing now, it just lost boost. However these might still be possible and I guess i'll have to open her up and check all my couplers that might have gotten loose due to the heat.
The noise and loss of power the car is making now is similar to having a wrong intake tune (but again I mapped the stock tune and issue persisted) where is just spits and jerks the car a bit making exhaust spit out air kind of like it was in the rev limiter.
Old Aug 29, 2016 | 10:14 AM
jhkuse's Avatar
Thanks for the assistance man but unfortunately that is not the issue. I did check all the areas around the intake, BOV and 3Port. I have the stock BOV so its recirc all the way as well.
Old Aug 29, 2016 | 10:19 AM
4G63_EVO's Avatar
but you physically took off the BOV and checked the spring? Damn, im not sure what else you could check
Old Aug 29, 2016 | 10:50 AM
jhkuse's Avatar
I did not take the BOV off the holder at all, but I'll make sure I check inside of it to check the spring just in case!
And yea man im all sorts of confused. I made an appointment to get her checked out at Mitsubishi until NEXT freaking Wednesday, I know I should go to a performance shop but unfortunately I'm not close by any of them and I don't want to drive the car like this for 3 hrs.
Meanwhile she's going to keep sitting in the garage and I'll have to keep riding the motorcycle in this damnnnnnnnnnnn heat
Old Aug 29, 2016 | 11:59 AM
.M.'s Avatar
.M.
No luck huh? Well... keep us posted. Very interested to hear what the isssue is/was.
Old Aug 29, 2016 | 01:23 PM
jhkuse's Avatar
will do. The suspense of waiting until next Wednesday is gonna kill me! I'll probably take the bumper off this weekend check out the intercooler piping and see how all that is holding up.. the only thing is this daaaaaang heat is going to kill me.
Old Aug 30, 2016 | 11:22 AM
4G63_EVO's Avatar
Definitely check the inside of the BOV could easily be your problem and its easy to check
Old Aug 30, 2016 | 12:29 PM
redlightrunner's Avatar
under the engine cover did you check the one on the left. its around the fuel line I believe. I know its known to pop off.
Old Aug 31, 2016 | 10:17 AM
jhkuse's Avatar
NO I did not check the fuel regulator hose!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I never thought of it since I only touched the intake, but this is a very promising solution. I cant say if that was the reason and I'll have to check that hose as soon as I get home this afternoon but that would make so much sense
I'll update this afternoon. Thanks man.
Old Aug 31, 2016 | 10:56 AM
4G63_EVO's Avatar
This slipped my mind as well! CHECK!
Old Aug 31, 2016 | 11:15 AM
.M.'s Avatar
.M.
^Good call. After buying an X, I thought everyone knew to secure that line and swap out the relays.
Old Aug 31, 2016 | 11:17 AM
Epyon's Avatar
Is the fuel hose problem still a thing in '15 evos? I know Mitsu fixed the relay issue from the fatory now, but not sure if the fuel hose coming off is still a problem or not.
Old Aug 31, 2016 | 03:26 PM
jhkuse's Avatar
Fml guys that fuel regulator was on tight with zip ties.... Wtf! I was so sure that was going to be it. But back to square one..
only thing I've noticed is the coolant hose the on in the back (if you are looking at the engine from the front) is loose and not attached to anything. I looked over the manual but doesn't say if that is normal or not. I also searched the forum but no luck.. Any body can give me a pointer to where that hose is Supposed to go to? Or vent freely?
