Sponsored by:
Sponsored by: CARiD
Charging System Service Required Light
Old Nov 5, 2016 | 08:36 PM
DontStopMe's Avatar
Hello EVOM,
My wife's 2011 Ralliart has the "charging system service required" light come on but on while driving on the highway. And she says it only happens while accelerating.
I check the battery voltage and its 12.9 when off and 14.2 when running. Everything seems to be operating normally. Car is 95% stock. Just has an intake and BOV. No aftermarket stereo or anything.
Any thoughts on what the issue could be? Anyone else ever have this light come on?
I've searched and it does not appear to be to common.
Any help is appreciated. Thanks!
Old Nov 6, 2016 | 04:59 PM
4b11slayer's Avatar
It sounds like a alternator.
Sometimes they will produce the proper voltage at idle and once put on a load they will die.
Im sure it will fail a true alternator test at the dealer. With all loads on and raised rpm.
I.e blower on high, high beams on, radio. Then raise rpm to 3k see what voltage is there.
Old Nov 7, 2016 | 06:39 PM
DontStopMe's Avatar
Thanks for the reply. A new alternator is on order. I will updated if it fixes the problem.
Old Nov 9, 2016 | 06:15 AM
DontStopMe's Avatar
Changed the Alternator and it has appeared to have fixed the issue.
Side note, changing the alternator is a PITA. The A/C line is in the worst place ever.
If you have to change your alternator, go into it knowing you need to remove:
1) Passenger Wheel
2) A crap tone of plastic
3) Radiator fans
4) UICP
5) Upper radiator hose
Old Nov 9, 2016 | 06:17 AM
4b11slayer's Avatar
Glad all turned out well sir.
Old Nov 9, 2016 | 08:57 AM
Veronica's Avatar
And thanks for the heads-up on removal...
apparittion
Jul 19, 2016 05:41 PM
Litcandl3
12
Nov 16, 2012 07:03 PM
Sheyko
13
Aug 22, 2012 10:41 AM
limx
Feb 28, 2012 07:36 PM
nef
Jan 31, 2010 09:59 PM
