Sponsored by:
Sponsored by: CARiD
Recaros from wrecked car
Old Mar 31, 2017 | 07:55 PM
moparfan's Avatar
Originally Posted by DBomb117
LMAO, I considered it for like .25 seconds.
That's what the grab handles are for.
Old Mar 31, 2017 | 08:48 PM
NinjaX's Avatar
The one from oem recaro worked fine.
Originally Posted by Cirielmd
so do you use the OE weight sensors in the 2015 or do you need the ones the recaros came with?
Old Apr 1, 2017 | 04:59 PM
DBomb117's Avatar
Stick to the one that came with the car, I installed the one that came with the recaros the first time and the airbag light came on. Had to uninstall and replace with car-original weight sensors to make it go away
Old Apr 1, 2017 | 09:41 PM
NinjaX's Avatar
Not sure in my case i only moved the seat bealts.
Old Apr 3, 2017 | 09:02 AM
wave5000's Avatar
When I did the recaro swap into my 2015 gsr I removed the weight sensors/seat belts and put them in recaros because these are linked to your ecu's data or whatever. That means my lancer seats are useless and I cannot sell them.
Old Apr 3, 2017 | 10:37 AM
c08's Avatar
c08
Is it necessary to swap the seat belts too, or just the weight sensors? I thought you could reuse the seat belt buckles from the Recaros (assuming they came with them), but I haven't done the swap so I don't know.
Old Apr 3, 2017 | 11:00 AM
wave5000's Avatar
Here's how I see it, when you strap on the belt and assuming you have a passenger also strapping the seat belt, the ecu should detect the same signal that came from your OE seat. By transferring both belt buckle/weight sensor to your recaros, the ecu still 'thinks' that it is still the OE seats and will not give you faults. When doing the weight sensor swap, you are already triggering a (weight under the seat light)fault after installation. When you bolt your assembled recaros and start your car the flashing seat belt light will flash (without a passenger ) but in my case the light went out the next day and will start working normally.
Old Apr 5, 2017 | 05:40 AM
DBomb117's Avatar
I would do both to be safe, that's what i did and no airbag light.
prj.evo
Midwest Region
Oct 10, 2008 03:34 PM
Paperchasin
Mar 19, 2006 11:00 AM
xtnct
Mar 3, 2005 12:02 PM
xtnct
Northeast Region
Mar 3, 2005 11:32 AM
