Sponsored by:
Sponsored by: CARiD
Stock Evo X shifter - Heavy or Light Shift knobs?
Old Jan 20, 2017 | 09:36 AM
  #31
static_set's Avatar
I use the Sneed baton - It's pretty light but still easy to shift with.
Old Jan 23, 2017 | 06:53 PM
  #32
Noize's Avatar
EvoM Administrator
I got a Moddiction Anvil 1. It's sweeeeeet!
Old Jan 23, 2017 | 08:08 PM
  #33
Trifling's Avatar
Originally Posted by CaptainCrunch
Does it?? What knob is it? Is it weighted too?
I have the countersunked sphere by moddiction. And yes it's weighted. Very heavy
Old Jan 24, 2017 | 09:30 AM
  #34
UxC's Avatar
UxC
Veteran: Army
I've got the AMS V1 shift knob, and it's relatively comfortable. Not as heavy as I like them, but it makes for a nice grip.
Old Jan 24, 2017 | 10:05 AM
  #35
aaronp's Avatar
I've been using the same one for awhile and I'm very happy with it. It's taller than stock but not much heavier and seems to make shifting smoother. But the main factor was that it's resin and not metal, which is much nicer in the west Texas heat. I also installed the ams gate selector bushing which made the biggest difference in smoothness. 2nd gear still crunches occasionally but not like before.
Old Jan 24, 2017 | 10:06 AM
  #36
UxC's Avatar
UxC
Veteran: Army
Yeah.. Mine crunches in 2nd and 3rd sometimes. Even if it's warmed up.. I'll get those bushings replaced eventually!
Old Jan 24, 2017 | 01:53 PM
  #37
4EverWiKiD's Avatar
Veteran: Air Force
Just installed my TWM Type R, and I must say I'm impressed with the difference. I tried various height adjustments, and found the lowest setting to work the best. Decreased the notchy feeling significantly, and provided smoother gear changes. This is on a stock shifter too. I ordered the shifter cable and transmission bushings too. I'll be installing them with an ETS intake. I'll comment on my thoughts after that as well.
Old Jan 27, 2017 | 05:28 PM
  #38
moladin's Avatar
Off topic, but might as well go all the way and install shifter cable bushing too. Do not buy Works one, it will slip off and one day you will wonder why you lost 3rd gear while driving. Scary as hell when it happen. Get Torque Solution one instead.
Torque Solution Shifter Cable Bushings :http://www.torquesolution.com/Mitsub...ts-scb-100.htm
Install that is a bit time consuming however.
Ralliartize It
39
Apr 20, 2015 10:07 AM
BPAuto
Evo 'For Sale' Interior Styling
19
Apr 11, 2014 05:07 PM
BPAuto
EvoX 'For Sale' Interior Styling
35
Jan 3, 2014 01:35 PM
BPAuto
15
Jun 11, 2013 01:59 PM
lution#9
May 21, 2006 06:09 PM
