Car won't crank!... Any advice?
Long story short. I bought used 2010 Evo X MR SST, the car was after accident somewhere and was repaired as a piece of ****, ok. The problem is that it won't crank. There is keyless go system, the remote was w/o fast key, but I put there fast key from another Evo X and I think it have to work with no issues and after that what happens:
All the lights on the cluster goes on, everything around works
All the fans starts
We tested the remote and chip is working
All the doors opens and closes with remote
What I have done to find a solution {and nothing happens}
Changed all the relays
Changed brake pedal switch
Changed ignition switch
Starter works
Any advice??? Thanks
All the fans starts
Starter works
Have you tried pulling trouble codes with an OBD reader?
heyythurr
Nov 3, 2014 11:52 AM
_des_
Mar 8, 2012 07:56 PM
hybrids14
Mar 19, 2007 01:06 PM
