Sponsored by:
Sponsored by: CARiD
Oil on top of the airbox after autocross runs
Old May 12, 2017 | 03:19 PM
Prime12's Avatar
I always find a small amount of engine oil (maybe a few drops) on top of the stock airbox after an autocross run.
Every. Single. Time. Without. Fail. Since I got the car in 2014.
I never paid attention to it, but what could be causing this?
Even if there is a leak in my oil cap (I don't think there is), I find it highly unlikely that the oil could be traveling that far.
Could it be a bad PCV valve? I've never had my dipstick pop off though.
Never happens outside autocross but I almost never get into boost outside autocross so that may have something to do with it.
Any ideas? Car is stock.
Old May 13, 2017 | 06:28 AM
migs647's Avatar
In for seeing suggestions. I haven't seen anything like this before. My guess is there is some blowback happening, but on a stock airbox? A bit perplexed.
Old May 14, 2017 | 06:21 PM
.M.'s Avatar
.M.
So just on top of the air box? No other parts/areas at all? That is weird...
Old May 15, 2017 | 08:07 AM
static_set's Avatar
Oddly enough I had this same thing happen when the engine was under similar conditions to an auto-x.
Turns out that when I replaced the valve cover gasket I tightened them all down in the wrong sequence and the crankcase pressure was misting oil past the gasket on the driver-side and it was collecting on the airbox.
Check that first.
-asher
9!'clipseDOHC
Mar 3, 2015 06:51 PM
thegoodservant
Mar 24, 2011 11:15 PM
EVO8LTW
Jun 22, 2007 09:10 PM
