Sponsored by:
Sponsored by: CARiD
Cusco rear strut bar owners: did installing the bar require cutting factory plastic?
Old Jun 2, 2017 | 12:57 PM
Lightsaber's Avatar
Question Cusco rear strut bar owners: did installing the bar require cutting factory plastic?
Cusco rear strut bar owners: did installing the bar require cutting factory plastic?-fqmoriz.jpg
Here is a picture of the Cusco rear strut bar installed, from Celtic Motorsport's webpage. I'm wondering if installing the bar requires the factory plastic cover (for the battery and washer fluid) be cut in some ways to fit. I myself want to retain the plastic cover as much as possible to keep a neat look and prevent luggages from damaging the battery mount.
I really appreciate any inputs, and thanks in advance.
Edit: It's somewhat real hard for find any relevant information, but I found an old post that appears to suggest no cutting is needed:
Old Jun 2, 2017 | 02:48 PM
evo 1768's Avatar
NO No its no necessary to cut the factory plastic. Only if you buy Suspension Strut Brace-Rear MITSUBISHI.OEM MZ574598EX
Old Jun 2, 2017 | 04:18 PM
Lightsaber's Avatar
Oh wow, thanks a lot!!! I was debating whether I need a shop with fabrication capacity to install the strut brace. Since no cutting of the factory plastic is needed to retain the plastic cover, I'm going to simply call my dealer to install it.
Old Jun 22, 2017 | 05:36 PM
Lightsaber's Avatar
Postscript
I just had the Cusco strut bar mounted!!!! The cover can be re-installed perfectly. Thank you, thank you, thank you evo 1768!!!
ExtremeDSM
35
Feb 27, 2017 06:54 AM
kpt6
26
Feb 10, 2015 12:47 PM
kpt6
13
Nov 9, 2014 05:27 PM
acidandroid
15
Jan 12, 2008 03:27 PM
