Sponsored by:
Sponsored by: CARiD
Clutch and Gearbox
Old Aug 17, 2017 | 12:58 AM
dxn036's Avatar
Clutch and Gearbox
Everytime I shift to 3rd or shift into Reverse, it always grinds. Also my clutch squeaks everytime I push it in. Any recommendations for a good clutch system that the clutch is soft and I'm able to shift smoother and faster?
Old Aug 17, 2017 | 06:15 AM
Napalm_Enema's Avatar
You should start with changing out your transmission fluid and getting a heavier shift ball before you start moving on to the more expensive things.
If you can wrench yourself: http://www.evoxforums.com/forums/showthread.php?t=14420
A lot of people I've read have said good things about this cocktail for the fluid:
https://www.maperformance.com/produc...ishi-evo-x-gsr
As for a heavier shifter that could help. Past that you could have a synchro issue if you have a grind into third, so you may be looking at more expensive fixes if the fluid change etc. don't help.
If you end up needing work done, you are in CA so you could look up 5150 they are really great with EVO's.
Old Aug 17, 2017 | 06:52 AM
4b11slayer's Avatar
Does the clutch slip? How many miles on it?
I think fluid would be a waste on a already grinding trans.
It could be a clutch issue. With the pressure plate not fully colapsing or it may need to be re synchrod and inspected for further damage to gear stack.
Old Sep 5, 2017 | 08:09 PM
1337's Avatar
Could be bad synchros or clutch drag either way drag kills synchros, an exedy twin non rigid would take care of trans and give u best shifting experience also DD friendly
RSMike
Feb 10, 2011 11:13 AM
joedr
14
Jun 15, 2008 07:55 AM
sleeper3
Jun 10, 2008 11:55 AM
MaxBoost
Oct 15, 2003 06:24 PM
