Sponsored by:
Sponsored by: CARiD
recommendations on shifter extender please.
Old Sep 18, 2017 | 04:29 PM
CaptainCrunch's Avatar
Hi... got one off the bay.. I can still see tons of thread on the stock shifter rod even with the extender on. Any tips on where to get a better steel extender? Thanks.
Old Sep 18, 2017 | 04:51 PM
donny_utah's Avatar
Veteran: Army
Not an extender. But I've the AMS shift knob. It's long, thick(hurhur) and sits high and really fills your grip wether you use a full grip or slight top only grip.
Old Sep 18, 2017 | 09:09 PM
Kishin's Avatar
Hey Donny which one did you get? Well I have the AMS carbon fiber shift knob and it's much taller than the stock aluminum on that came with mine. Now AMS also makes a V2 version of it and I've yet to see it in person but it might be taller.
Now OP, a quick Google search shows Torque Solution having one that's 3in tall. I don't have one so I don't know how well it sits. If you have more money so spend for it you can always go to your local machine shop and if they have a lathe they'll make you one.
Old Sep 19, 2017 | 01:06 PM
static_set's Avatar
I use the Torque Solutions type with the long Tomei shift knob. Works great and matches everything in the interior.
Old Sep 19, 2017 | 04:44 PM
donny_utah's Avatar
Veteran: Army
Kishin, I've the non carbon fibre one. Looks identical to yours. Just non cf. Same size and feel.
Old Sep 20, 2017 | 06:43 PM
Thanks. Already have a weighted shifter, and the AMS is way too light. The extra length is even nicer, imo.
Thanks Kishin. I checked torque solutions and it looks like they have aluminum only. Wanted steel. And wouldn't even know where to go find a machine shop around here to do that.
Does it cover the oem rod's threads completely? Its aluminum right? Any flex at all? Any chance you have a pic? Thanks.
Old Sep 21, 2017 | 11:39 AM
static_set's Avatar
Aluminum works just fine if you dont drive around slamming gears like an idiot. I'd rather snap a shifter than strip a synchro. Tomei builds a featherweight shift knob, always worked well for me.
Sure, here you go.
Old Sep 29, 2017 | 12:07 PM
Appreciate the picture. You like a light shifter? For me using a heavy shift knob has smoothed out the shifts a ton.
Old Sep 29, 2017 | 02:35 PM
Nicolas's Avatar
Originally Posted by captaincrunch
appreciate the picture. You like a light shifter? For me using a heavy shift knob has smoothed out the shifts a ton.
+1
Old Oct 3, 2017 | 01:32 PM
static_set's Avatar
I've always preferred a lighter shift regardless. It's more responsive (IMO) and easier to correct a miss. With a light shifter I can actually feel for proper synchro engagement rather than forcing it through the gate if that makes any sense.
Ruthless.
24
Mar 24, 2014 10:21 PM
nlp187
Jul 8, 2012 10:32 PM
Don Q
24
Jun 18, 2012 07:57 AM
motocooney
Apr 17, 2011 05:42 AM
TRDHarrier
Aug 14, 2003 08:31 AM
