Sponsored by:
Sponsored by: CARiD
AFR changes over time by itself!!!!!!
Old Sep 19, 2017 | 10:22 PM
jamaicaboost's Avatar
Ok, I tune the car at a perfect 11.2 AFR at wot, then drive for 30-40 minutes and it slowly lean out to 11.8 AFR at wot!!!! Ntn changes except the time thay has passed driving. Then stop and turn off engine 2 minutes, drive again and back to normal for a while, then all of a sudden AFR gets lean again. What is the problem? Basically after tuning AFR changes by itself and gets leaner, the fluctuate from set AFR to different leaner afrs... Some other times AFR gets richer, to 10.4 wot, then go back to leaner, all by itself.....wht should I look at?
Old Sep 19, 2017 | 10:35 PM
4b11slayer's Avatar
Temp.
Old Sep 19, 2017 | 10:44 PM
RazorLab's Avatar
Turn off fuel trim affecting WOT fueling
Old Sep 20, 2017 | 07:04 AM
Which table exactly turn off fuel trim?
Old Sep 20, 2017 | 07:35 AM
Biggiesacks's Avatar
in my xml its labeled "Closed Loop - LT Trim Control"
tsitalon1
Apr 13, 2014 01:19 AM
bobby.is.rad
Apr 6, 2012 09:19 AM
EVO IXMR
Nov 14, 2010 07:56 AM
pileofparts
Jul 13, 2010 10:45 PM
