Sponsored by:
Sponsored by: CARiD
need help evo x map tubular exahust manifold
Old Sep 27, 2017 | 04:09 AM
Sleeper_evo_X's Avatar
good day guys just a quick help if anyone of u guys encounter removing the stock exh manifold and replacing it with aftermarket one, how did u install it back, do u have to remove the downpipe and the turbo to install it, or is there a way to put it back with out removing those parts. Let me know thanks.
Old Sep 27, 2017 | 03:43 PM
Projectjdm's Avatar
You will probably have to remove the turbo support bolt on the block and lower the turbo to clear and if you want to make it easier remove the studs on the turbo and replace with bolts.
Old Sep 27, 2017 | 04:28 PM
asuarez's Avatar
What the gent said and the side/top support of the turbo. Patience, lots of patience.
Old Sep 27, 2017 | 06:38 PM
got it through without removing anything its a ***** but can be done i said to myself **** let me find a way to squeeze it without removing anything now that its installed i need the right tool combination to whoever done it what kind of special tools u got to use for it if any and also if theres a sequence to tight all of it and whats the torque spex
Old Sep 30, 2017 | 03:10 PM
ossimbrian's Avatar
LOL I also recently purchased a MAP tubular manifold. The nut and stud that holds the turbo to the stock exhaust manifold decided to spin together... im at a loss for words
RedLanEVO
Apr 27, 2014 07:25 PM
blackevolution8
Mar 16, 2010 06:14 PM
thekuai
10
Feb 26, 2007 12:53 PM
kasia
12
Apr 11, 2004 02:06 AM
