Sponsored by:
Sponsored by: CARiD
maintenance help for a noob!
Old Feb 27, 2018 | 08:48 AM
CaptainCrunch's Avatar
Which is the proper part number for trans oil for a GSR, MZ320197 or MZ320195?
And as far as the diff goes... there are two parts of the service, how crucial is the torque transfer part that takes the diamond atf sp III? I was thinking about foregoing that part.
Old Feb 27, 2018 | 08:52 AM
Oh! And any tips on which site to get the oils from? I was looking at maperformance.
Old Feb 28, 2018 | 06:21 PM
Honeymelon's Avatar
Are you talking about your transmission fluid? Or your rear diff. Both use completely different fluids.
If you're talking transmission fluid, I'd recommend the cocktail blend of Redline MTL. Very reputable and makes shifting a lot less clunky. I used OEM tranny fluid when I swapped out my clutch and I hated it, went to Redline and made a worlds difference.
https://www.maperformance.com/collec...ishi-evo-x-gsr
And if you're talking about the rear diff, refer to this picture. I would just do both while you're down there and have the car lifted up. Kill two birds with one stone. LSD Diaqueen Gear Oil smells real gross too. (: Hope this helps.
Old Feb 28, 2018 | 06:48 PM
Thanks Honeymelon! I was considering the Redline for the tranny, but figured I'd stick with oem while under warranty. But the smoother shifting is enticing because right now it is notchy.
I was asking about the rear diff. I didn't know it was a 2 area process and admittedly I am not handy working on my car. My friend is going to take care of it for me. Hes very knowledgeable. At this point I just want to make sure I get the right oil. Which of those two areas for the rear diff is the more commonly done 1? I am confused. The "Differential Mechanism Part" is the more commonly done area? I initially thought the "Torque Transfer" part was the regular... but that takes the weird Diamond oil making me think it isn't the common area.
Old Feb 28, 2018 | 06:52 PM
Too long... basically trying to figure out which of the 2 diff areas is more commonly done so I know which oil I need for that. AYC = torque transfer mechanism or differential mechanism??? HELP!
Old Feb 28, 2018 | 08:43 PM
Honeymelon's Avatar
Do them both. You only need like half a quart for both. And doesn't the work need to be done at a recognized shop for it to be counted as warranty? And if you're worried about warranty then stick with oem fluids and just suck up the clunky gear box. Service manuals recommend you change them both at the same mileage/kilometres. Idk. Seems self explanatory to me. Ps don't cheap out, change out the washers too. (:
1 quart of Diamond ATF SP3 : MZ320200
1 quart of LSD Gear Oil Diaqueen: MZ320345
Old Mar 1, 2018 | 12:08 PM
hichamaziz's Avatar
thank you Honeymelon for website
Old Mar 12, 2018 | 04:03 AM
islaw's Avatar
Veteran: Air Force
Thanks you too
Old Mar 12, 2018 | 11:35 AM
POWAAH's Avatar
Subbed for future use
Old Mar 21, 2018 | 11:01 AM
Thanks for the tips. I am hearing from many reputable places that the part that requires the Diamond fluid isn't necessary. Shoot, even Mitsubishi dealer techs say so! "Doesn't need a chance unless we replace the pump." Even from reputable Evo shops recommended here say the same!
Old Mar 27, 2018 | 07:51 AM
DeweyD's Avatar
Oh boy a rear diff thread! You are confusing the resovoir, pump, acd/ayc lines with the rear diff clutch section (both us atf fluid). They are two separate areas. The resovoir/pump/line fluid does not need changed that is correct. But the rear diff unit picured in the previous post (both gear oil AND atf part!) needs changed regularly.
Stop getting confused by this people!
Old Mar 27, 2018 | 07:28 PM
Hey. Thanks for replying. I am looking at the picture above, and thats what I am talking about. "The differential mechanism part" needs changing, according to everyone. But the other part, the Torque transfer mechanism part" is what I am being told by a bunch of places doesn't need replacing.
Old Mar 28, 2018 | 08:23 AM
DeweyD's Avatar
BOTH need changed, that's what my last post just said. People confuse torque transfer mechanism with resovoir/pump/line all the time on here. They BOTH use ATF but one is regular maintenance, one only needs changed and bled if you open it for some reason. The pump/line ATF bleed procedure was NOT shown on the page above. The entire page image posted before needs to be completed as a part of regular maintenance.
what are these places and who are these people telling you otherwise or are you misinterpreting what they are saying?
Old Mar 28, 2018 | 08:26 AM
DeweyD's Avatar
Let me be more clear. If your Evo has an AYC rear diff (all North American Evo X's)...
When you do fluid maintenance on the rear diff, you should have opened TWO drain plugs and TWO fill plugs and used TWO different types of fluid.
i just did this on an Evo X and will being doing it on my X again here soon. If there are no good youtubes on the process I will try to document mine for posterity.
Old Apr 5, 2018 | 07:34 PM
Thanks for the help. I know nothing about wrenching and this rear diff stuff has been a real pain. Doesn't help that the dealer/reputable shops are saying not to touch anything involving the SP3. I got confused and legitimately asked "So none of the SP3 fluids need to be changed?" And was given a solid no. Mitsubishi dealership in NJ had their "Evo tech" talk to me as well as Ivey Tune.
Meh don't care about all that. So to clarify, do the SP3 fluid that is pictured above.. and the procedure is simple as what the directions say? Flush and fill, basically? Thanks a ton.
