big dilemma: low oil pressure..THOUGHTS?
hi guys.
my car shut off out of nowhere when I came to a stop and it barely restarted. I noticed the engine temp growing quickly by ~1 degree/sec, so I pulled over.
No leaks, oil level is fine. I start the car and notice 2psi of oil pressure at 500rpm. no engine noises yet.
I had to get home, and limped myself home staying between 1k-2.5k of RPM. Going over 2.5k RPM resulted in rapid engine temp rising, and going under 1k stalled the car. I had super low oil pressure limping back home. Stop lights and traffic were a pain, as I modulated gas pedal for the car not to die. The engine developed a rattling/ticking noise which was exacerbated with giving it any throttle. codes: P0365, P0011, P0014 (mivec control valve issue)?
This has all happened after I got my valve cover powdercoated. There seemed to be some sandblast material in the baffles (don't know if this is related to my problem).
TL;DR:
-oil level fine
-no leaks
-no oil visibly being burnt
-low oil pressure
-car stalls <1k rpm
-car gets hot >2.5k rpm
-p0365,p0011,p0014 (mivec issue?)
-valve cover was powdercoated prior (sandblast material in baffles)
-rattling/ticking noise that is exacerbated with giving it gas
-AFRs looks fine, and the car can build boost
any help whatsoever is appreciated..entirely bummed out.
TL;DR:
-oil level fine
-no leaks
-low oil pressure
-car stalls <1k rpm
Wait, are you saying that it is a bad idea to start and operate a mechanical device that relies on stable oil pressure...with no oil pressure?
need a new head, crankcase, bearings, etc. going with a straight swap.
besides the timing chain revision or plastic valve cover, are they any surprises I should know about when swapping a 2011+ engine into my 08 (e.g. engine mounts, ECU issues).
thanks for discussing my ill fate xD
the potential swap is a 2014 engine
