HPDE- OK to use ST43 front pads, DS2500 rears?
I'm swapping front Ferodo DS2500's for Raybestos ST43's for track days. Is it necessary to do the same for the rears? I'm reading mixed opinions online, but for EVO X this seems OK, particularly because the rears are DS2500's. I'm an "intermediate" level racer. I have stainless steel brake lines, fresh ATE DOT4 fluid, new Falken Azenis RT615K+, and I have a tune for 275 HP to the wheels. Everything else is stock.
Also, how long should I be comfortable with keeping my track pads on? For example, if you have a track day on a Wednesday, and another on a Sunday, would you just leave your track pads on between those events and drive carefully on the street? It seems maybe unnecessary to swap track pads on/off/on if there's a short time between events.
Doubt necessary unless really pushing things most braking for the front. Past track day you'll want to change them just due to the annoyance factor. They will be very loud and squeal a lot until up to temperature. So most don't like to use track pads on the daily due to that aspect.
ST43 front and DS2500 rear has been fine for me.
Coefficient of friction for DS2500 declines as temperature increases. I can't find a graph for ST-43, but they definitely become more grabby as they warm up. Both pads have approximately similar coefficients of friction, so the setup doesn't feel too unbalanced. The combination feels front-biased at temperature, which isn't necessarily a bad thing for HPDE.
My ST43 didn't really make much noise on the first drive out to the track. After the track day, they became unbearable. I can't wait to swap them out when I get home.
