Sponsored by:
Sponsored by: CARiD
Evo X fluid change
Old Oct 3, 2020 | 05:19 PM
AvgJo97's Avatar
Evo X fluid change
I did my engine, trans and rear diff fluid change today on my evo x. I filled my rear diff and trans fluid to fill plug level, is that too much? TIA also what fluid do you guys recommend for winter months? I live in Canada and it reaches -30C +
Old Oct 4, 2020 | 12:29 PM
.Adam's Avatar
As long as the car was level then I think you should be okay. The rear diff may be different though. I would be specific with those fluid levels.
I use OEM fluids for everything except the trans. For that I have used the Redline cocktail.
Old Oct 4, 2020 | 01:20 PM
AvgJo97's Avatar
I ended up using oem for everything but I heard the redline works really well with transmissions. I also heard redline for ayc (on back side of rear diff) is good for winter months because the oem stuff tends to freeze
Old Oct 5, 2020 | 05:56 AM
.Adam's Avatar
I live in Winnipeg so I know about freezing
I've only used OEM fluids in the rear diff and have had no issues. I've had this car for over 7 years and drive it every winter
RATEDX
Mar 15, 2016 05:42 PM
OldManQuentin
Apr 14, 2014 07:05 PM
trboboost91
Jul 22, 2012 06:58 AM
Kilratio
20
Feb 9, 2007 03:27 PM
