Water Pump Underdrive pulley
This not advisable. One person makes an underdrive pulley for the 8/9 and it caused my car to over heat on track. Back to stock pulley, and it ran 210 all day just fine.
If you need more power, run E85 and/or put a bigger turbo on the car.
I worry that the lightweight crank pulley will not dampen the engine vibrations as much as needed for track use.
In any case, I've moved on from looking for an underdrive pulley and am going with an electric water pump.
I pulled the impeller off the existing mechanical water pump and am putting the electric waterpump at the radiator output so that it pushes water through the whole system. I'll remove the thermostat as well and let the electric water pump controller manage everything.
water pump with impeller removed
Folks, I have recently purchased a Megan Racing underdrive aluminum pulley; would anyone know the specs of the correct V belt for it(or any underdrive pulley), thanks in advance.
[WTB] Evo 8 Water Pump Pulley
Acuality
Jul 17, 2016 08:27 PM
