Water pump delete belt routing
Has anyone here deleted the water pump? I have a dedicated track car and am running into serious overheating / water pump cavitation issues. Engine is stock.
I’m putting in an electric water pump and I want to remove the existing mechanical water pump impeller and pulley.
What belt routing can I use with the water pump pulley removed?
What size belt?
Thanks!
What size belt?
Thanks!
What size belt?
Thanks!
What size belt?
Thanks!
Is it possible your factory pump is failing? I haven't really read anything about anyone having issues with the factory setup even on full race car builds. You can also look at running some Water Wetter or similar product that won't produce a coolant slick but helps with some issues when running straight water.
I'm currently installing a BMW CWA400 electric water pump.
04rallikid
May 10, 2010 12:19 PM
