Sponsored by:
Sponsored by: CARiD
Gas smell when I turn on the ac or heater
Old Oct 11, 2022 | 05:01 PM
BryanSorto10's Avatar
Hello, I recently purchased a used automatic evo x and it has 66k miles on and recently I be getting a gas smell when I turn on the ac or heater and I can see a white smoke coming out on the hood but not a lot. Do you guys have any clue?
Old Oct 12, 2022 | 02:37 AM
varv's Avatar
Hi. Seems like you are losing fuel somewhere but that can be several different things:
  • Check for leaks all the way that fuel is going thru engine, especially near injectors.
  • Check if the evap tank isn't full
  • Check if oil catch can isn't full if you have one
Old Oct 12, 2022 | 06:45 AM
bcollins92's Avatar
Do you have a catch can in your engine bay with little filters on top?
Old Oct 12, 2022 | 07:56 AM
I don’t have catch can in the engine bay
Old Oct 12, 2022 | 07:57 AM
Thanks I’ll check it out later day and I’ll keep y’all updated.
Old Oct 12, 2022 | 08:56 AM
bcollins92's Avatar
Where does the white smoke come from?
Old Oct 12, 2022 | 09:07 AM
Where my air intake is located
Old Oct 12, 2022 | 10:00 AM
ViciousLSD's Avatar
maybe an exhaust leak? or your pcv is clogged
Old Oct 12, 2022 | 10:38 AM
bcollins92's Avatar
Can you post a photo of your engine bay?
Old Oct 12, 2022 | 11:50 AM
when I get home I’ll post a picture of the engine bay
Old Oct 12, 2022 | 11:52 AM
I’ll give that a look too because the car didn’t have an catalytic converter so the dealership put one before i bought it
Old Oct 12, 2022 | 02:35 PM
Old Oct 13, 2022 | 06:35 AM
bcollins92's Avatar
Where does that clear hose on the drivers side route to?
Old Oct 13, 2022 | 09:23 AM
RobbieOh's Avatar
5 Year Member
That does look like a catch can hose.
Old Oct 13, 2022 | 01:40 PM
cwojcik's Avatar
Maybe make sure the injectors are sitting tight in the rail? Sometimes O rings can deteriorate over time and it will leak there which is a big problem.
