Evo X handbrake problem
Hi
I have a problem with the handbrake on my evo x. when I engage the handbrake, it locks all four wheels. Does anyone have an idea what the reason could be because I'm already missing it.
I found two trouble code but they don't show up on the dashboard :
U0251
C1290
Abs sensors are ok and the handbrake sensor too. And olso I have evo x rs rear diff and diff pump.
Thanks for help.
U0251
C1290
Thanks for help.
How do you know it locks up all wheels? The parking brake is a mechanical system, a cable that actuates the drum brakes in the rear, not much different than on a bicycle. Should have nothing to do with the fronts.
I see how the car behaves and I see that all the wheels stop when I pull handbrake. I guess the braking system itself has nothing to do with it, it's just a matter of the ACD not disconnecting. The same problem is when You have broken handbrake sensor but mine is ok.
I need to check it when I dissconect the diff pump but now I don't have time for my ex.
