Rough idle dies below 1500RPM
I have a built x, when I went to connect the battery to take out of storage it starts, idles really rough and eventually dies, if I give it some gas it will run normal at higher RPMS. I checked all the vacuum lines, fuses - spark plugs are going to be replaced shortly. Not sure where to go from here.
Note: While connecting the battery, i accidently hit the wrench while connected to the + battery terminal that causes a brief spark. ;
Edit: Changing spark plugs, and cleaning MAF tonight.
nathanr
20
Aug 31, 2014 07:16 PM
turboj
Aug 13, 2006 01:52 PM
