Sponsored by:
Sponsored by: CARiD
Advice for Potential Build
Old Feb 18, 2025 | 10:02 AM
Crisspy's Avatar
So i've been snooping around for potential car builds. I am really considering an Evo X build. I think I'm set on a 2014 GSR. I want to do the whole 9 yards, with a fully built engine. I want to see if I can find a salvage evo, at auction or wherever I can get my hands on one. What are some things I should look for if I do decide to pick up an Evo that is worth restoring. I found some that seem to have very minor damage. The only thing I am worried about is the overall chassis. If I can find one with the chassis in good condition, I don't really care how the motor or trans is. Any tips or advice would be appreciated. Is there something I should be on the lookout for, or to avoid completely?
Old Feb 18, 2025 | 01:30 PM
schuhie's Avatar
First I'm going to plug the same thing I tell everyone looking at modding their evo, actually think about your planned use case and build to that, not for dyno numbers.
Stock power is a way more fun canyon car than a 1000whp drag car would be and visa-versa. There is nothing worse than seeing someone build something and then decide to part it out or sell it because it doesn't fit their actual use.
Think through if its a street car, road course, auto-x, or drag car and go from there. You will save a lot of money and time.
Now to your actual question, I would personally try to find one that wasn't in a wreck but instead has a bad engine or driveline. Starting with something that was in a wreck is just asking for additional work that likely isn't worth it, let the super serious racecar people deal with that lol.
Other than that, rust or being a flood car would be at the top of my nope list.
Old Feb 18, 2025 | 01:56 PM
Crisspy's Avatar
Noted! I guess my use case is to be occasional track use, car meets, and spirited driving. I don't want a drag car or beat records on a dyno. I want to get good power, but "reliably". I don't know if this is dumb or not but my plan is to go a tad overkill with my build than for what I actually need, that gives me plenty of head room or a larger margin of reliability. I definitely don't want to mess around with the limits of stock capabilities. I am not super familiar with the platform, so I don't really know how far stock internals can go, and id rather not even take that gamble.
Old Feb 19, 2025 | 07:32 AM
schuhie's Avatar
The stock evoX bottom end is good for around 400wtq if I remember right. In my opinion, that is about the perfect amount for a fun street car.
It allows you to keep everything else simple as well as count on the factory engine instead of a built one for reliability.
If I were modding an X for mostly fun street things, I would do a like an MHI 18k, walbro 255, some ID1300x or ID1700x injectors and E85, preferably flexfuel if thats a thing on the Xs, I'm not 100% sure as I have a 9, and maybe some cams like GSC S2s.
This would get max fun with minimal investment while keeping it as simple and reliable as possible.
Don't let the stock bottom end scare you, if you go dig around the dyno page there are tons of stock bottom end stuff making serious power.
Old Feb 19, 2025 | 08:34 AM
ViciousLSD's Avatar
A lot of people dont post when their engines break tho The last guy i know to be very proud of their stock bottom has been out of the evo game for 3 years
Atleast get an upgraded oil pan if you're doing track
Old Feb 19, 2025 | 08:46 AM
schuhie's Avatar
This is also true lol.
I think this is more a keep it simple and reliable thing to me. I wouldn't lean on the stock bottom end for some numbers when its just a street car.
The upgraded oil pan is a good call if he plans to road course it though 100%
Old May 2, 2025 | 01:03 AM
Lightsaber's Avatar
You might want to consider a brand new Connect & Cruise crate powertrain from General Motors. The LS3 and T56 Super Magnum 6MT will give you about 430 brake horsepower. The LS376/525 and T56 will give you about 525 bhp. There is even a LT1 and T56 choice, where the new and fuel-efficient LT1 can be optionally configured with a dry sump, will give you about 460 bhp. And you need a nationally renowned shop for the installation.
This way, you lose all-wheel drive, but retain the stock car reliability. Buying and installing a GM crate powertrain will also likely cost you a lot less in the long run, when compared to messing around with the super-complicated, turbocharged, and actively-yaw-controlled Evo X AWD powertrain.
Personally, I don't like messing around with the Evo X's powertrain. A lot of my friends in the club ran into complicated and costly-to-fix mechanical problems with their supposedly full-boltons-and-a-tune Evo X.
By the way, you also want to take driver training and HPDE coaching very seriously. The stock Evo X is already powerful. A modified Evo X is scarily powerful. Don't be that guy who we miss and memorize.
Last edited by Lightsaber; May 2, 2025 at 11:20 PM. Reason: Added the LT1 + T56 option
Old Oct 27, 2025 | 11:23 AM
cursorman's Avatar
Solid plan — the Evo X GSR is a great platform if you start with a straight chassis. When checking salvage cars, pay close attention to frame rails, suspension mounting points, and any signs of previous structural repair. Minor body damage is fine, but chassis alignment issues can turn a build into a money pit. Compliance & Safety Support – Many dispatchers help track hours of service, permits, and other regulations, keeping your operation legal and safe, and companies like https://avnlogisticstm.com/ AVN Logistics apply that same attention to detail in their coordination, which is a mindset that works just as well when planning complex car projects. With the right base, you’ll save yourself huge headaches later.
wantingtobuyevo
Jul 11, 2024 11:59 AM
Elvin Castro
Nov 3, 2022 12:27 PM
slvrevo84
Dec 4, 2014 03:37 PM
ridenrunwv
10
Jun 16, 2009 09:27 AM
06redMR
Feb 24, 2007 05:01 PM
