Map evo x tubular manifold and 3.5 intake
anyone have a map tubular mani on and 3.5 intake did they tell a diffrence before and after, what kind of set up do you have ect turbo ect..
thinking of adding one to my set up but not sure i have all ams goodies but have a map ef4 513whp but my ams intake (3inch) is max out maf and if i was going to change intake and get retuned i was thinking of changing the mani is it worth it |
Thanks i ve seen that but i was wanting someone who has it on there car not just a shop car, and driving it everyday
I have it, i've had it installed for 4 days. I've driven with it, i installed it and overall it's ok. The install is awful, loosen the turbo, and balance the manifold on the studs whilst the bolts are very hard to get on. As far as performance, i'm getting tuned on Tuesday, but the car is running well. The fitment is good. Overall for the price, it's a good in between manifold. In between a $1500 manifold and an ebay manifold.
Originally Posted by philamthebest
(Post 9889290)
Have you thought about their smalled manifold? I can tell you not to buy the heat coating, you should but the heat wrap from an external source and wrap it yourself.... I'll post results from Tuesday next week.
(Post 9890296)
Well i just picked up a red two days before and installed that. before the fp red and injectors and manifold i was making 326hp. How about you? What is your goal? Mod List:
AMS Upper Intercooler Piping AMS Front Mount intercooler AMS Single Catback Exhaust Ultimate Racing Resonated Test Pipe AMS Cold Air Intake AMS Down Pipe Injector Dynamics 1000cc injectors FP Red Turbo MAP Performance tubular Manifold AMS Under hood shifter bushings Grimm Speed Boost controller |
(Post 9891124)
AMS Upper Intercooler Piping AMS Front Mount intercooler AMS Single Catback Exhaust Ultimate Racing Resonated Test Pipe AMS Cold Air Intake AMS Down Pipe Injector Dynamics 1000cc injectors FP Red Turbo MAP Performance tubular Manifold AMS Under hood shifter bushings Grimm Speed Boost controller Map EF4 ported exedy triple Ams intake 3 inch Ams innercooler Ams lower and upper piping Ams wide mouth dp Ams cat delete Agency power exhaust ID 1000cc injectors Ams fuel pressure reg kit AMs TMP cams Ams fuel rail Ams shifter bushing (All sets) Magnus clutch master cylinder AEm wide band 3 port grimmspeed kelford head springs 93 oct @ 30 psi falling to 27.8 513whp 447 wtq |
Originally Posted by 2003evo8
(Post 9888855)
wanting to get about 25-40 more whp with new 3.5 intake and map 4 bar sensor but is it worth the cost of a tune, but if i get mani and can get 50- 60 more whp it might be worth the tune.
trying for getting as close to 600 whp on dyno jet numbers of course but 500 whp on mustang dyno same either way but vd tells all! |
map rates ef4 to 600 whp thats what im trying to get safely my tune was very safe so with other mods might get alittle more aggressive
MAP tubular manifold is a fantastic piece! I saw killer gains:
https://www.evolutionm.net/forums/ev...ting-evox.html |
After being tuned today, the car is running great. During the tuning the manifold help up well, it was glowing, but help up for many pulls. All in all gained around 18hp from the manifold itself and the sound of the car is completely different due to the manifold. the exhaust has a deeper sound when you get on it, but the car idles quieter. I recommend heat wrapping the manifold once you get it. thats what i have done. Overall a good purchase and can't see spending anymore for a "better" manifold, this one handles great. so far.
(Post 9898241)
