P0016 code :l
Have full bolt ons/ mx1 cams / tuned by RRE. The day they tuned it check engine light came on. They checked timing and it's dead on. Any ideas of what it can be?
There is a TSB out for the P0016-17 code. I know you aren't on stock cams, but maybe Mitsu can flash it for you? When my P0016 went off it was my timing chain, did your tuner check for stretch?
Originally Posted by mshilto89
(Post 10866817)
I don't think you'd have to re-tune, but I would maybe ask the dealer first. At this point it seems like your safest option. I know a bunch of guys went in and got the TSB flash for the SAWC and some of them were tuned. I haven't heard of any flashes to them resetting the engine tune. Although, since this is technically a part of the drivetrain, it may mess with the tune. Wish I could be of better assistance?
https://www.evolutionm.net/forums/ev...p0017-cel.html
Here was my experience with the p0016 and p0017 code. |
Could be air in the actuator. Or a faulty oil control solenoid. How many miles since you had them installed?
Originally Posted by geoxrge_gsr
(Post 10863277)
Originally Posted by 04Evo851374
(Post 10868168)
I have a few mods and i had that code and one day i decided to replace my high flow cat with a straight pipe and check engine light came off. Turned out to be the cat. Mean while everyone said timing and my timing was dead on.
To the OP, when you say timing was spot on, are you saying that they visually checked the timing marks on the chain? A more accurate way to diagnose would be to log intakeVVT target vs actual in evoscan and see if 1) your intake camshaft is in time at idle and 2) that your intake cam is advancing and retarding properly within MiVEC. |
Originally Posted by rkelley
(Post 10867959)
(Post 10868362)
Not really sure what a cat has to do with intake camshaft position?
Any issues at idle? Stumbling? Lean AFRs cycling in and out?
