Sponsored by:
Sponsored by: CARiD
P0016 code :l
Old Jun 26, 2013 | 03:34 PM
geoxrge_gsr's Avatar
P0016 code :l
Have full bolt ons/ mx1 cams / tuned by RRE. The day they tuned it check engine light came on. They checked timing and it's dead on. Any ideas of what it can be?
Old Jun 29, 2013 | 01:11 PM
mshilto89's Avatar
There is a TSB out for the P0016-17 code. I know you aren't on stock cams, but maybe Mitsu can flash it for you? When my P0016 went off it was my timing chain, did your tuner check for stretch?
Old Jun 30, 2013 | 04:05 AM
Mines a 2012 you think I'd have to do it? But yeah they checked timing, if chain wasn't loose and stuff. Looks good. So yeah btw do you think since it's tune and the dealer flashes it, I would have to retune again or??
Old Jun 30, 2013 | 11:04 AM
mshilto89's Avatar
I don't think you'd have to re-tune, but I would maybe ask the dealer first. At this point it seems like your safest option. I know a bunch of guys went in and got the TSB flash for the SAWC and some of them were tuned. I haven't heard of any flashes to them resetting the engine tune. Although, since this is technically a part of the drivetrain, it may mess with the tune. Wish I could be of better assistance?
Old Jun 30, 2013 | 03:02 PM
mshilto89's Avatar
https://www.evolutionm.net/forums/ev...p0017-cel.html
Here was my experience with the p0016 and p0017 code.
Old Jun 30, 2013 | 05:22 PM
rkelley's Avatar
Could be air in the actuator. Or a faulty oil control solenoid. How many miles since you had them installed?
Old Jun 30, 2013 | 08:40 PM
04Evo851374's Avatar
I have a few mods and i had that code and one day i decided to replace my high flow cat with a straight pipe and check engine light came off. Turned out to be the cat. Mean while everyone said timing and my timing was dead on.
Old Jul 1, 2013 | 04:08 AM
rkelley's Avatar
Not really sure what a cat has to do with intake camshaft position?
To the OP, when you say timing was spot on, are you saying that they visually checked the timing marks on the chain? A more accurate way to diagnose would be to log intakeVVT target vs actual in evoscan and see if 1) your intake camshaft is in time at idle and 2) that your intake cam is advancing and retarding properly within MiVEC.
Old Jul 1, 2013 | 10:39 AM
Like 300 miles. Right when I left the shop my cel turned on
Old Jul 1, 2013 | 10:47 AM
Yes checked the marks on the chain, and it's good. My tuner also checked it on the Evoscan, everything seems to be normal. So idk /:
Old Jul 1, 2013 | 09:14 PM
rkelley's Avatar
Any issues at idle? Stumbling? Lean AFRs cycling in and out?
seeuarndjimmy
Jun 14, 2017 10:31 AM
tjac357
Jul 26, 2016 09:34 PM
newguyhere223
Jan 1, 2014 03:48 PM
landis
May 1, 2012 05:23 AM
CrazedRacing
Jul 19, 2010 06:56 PM
