How to: Make your own shift boot
Hey All,
Here is a little project you can do in about an hour, and only costs you about $5.
Below are the step by step instructions, and here is a link with step by step including pictures for each step.
http://picasaweb.google.com/cpavlas/...hiftBootOnEvoX
Items you will need:
- Seam splitter / or other cutting device (I used a pair of alternative lifestyle cutters, or dikes, for those that are non pc.
- Needle nose pliers for removing staples
- Small Philips and Flat Head screw drivers
- Scissors
- Material for making a new shift boot
- Marker for making the pattern
- Sewing machine (not necessary but makes it easier)
- Stapler, preferably a red one
Step 1: Dismantling the shift boot console
1 - Take off shift knob
http://picasaweb.google.com/cpavlas/...74365725804386
2 - Using your small flat head screw driver. Gently pry off the mini box area in front of the cup holders. You dont have to pry hard, so be gentle so you dont damage the plastics. Remove the cable plugged into the back of this box.
http://picasaweb.google.com/cpavlas/...74374315738994
3 - With the box removed, pull up, with some force, to pop the center area out
http://picasaweb.google.com/cpavlas/...74382905673602
4 - Now you can see the two screws holding the shift knob / ash tray / lighter
assembly in place. Go ahead and remove these two screws.
http://picasaweb.google.com/cpavlas/...74387200640914
5 - With the screws removed, gently lift up on the shift assembly. It comes up a lot
easier then the center console piece did
http://picasaweb.google.com/cpavlas/...74395790575522
6 - Unplug the lighter cable
http://picasaweb.google.com/cpavlas/...74404380510130
7 - Using your small flat head to push the leafs in on the connector holding the cable that goes to the lighter socket and remove the connector
http://picasaweb.google.com/cpavlas/...74408675477442
8 - With the shift boot assembly out, you can now easily remove the 4 screws holding it in place
http://picasaweb.google.com/cpavlas/...74412970444754
9 - Remove the shift boot from the assembly
http://picasaweb.google.com/cpavlas/...74417265412066
10 - Using your small flat head screw driver, remove the staples
http://picasaweb.google.com/cpavlas/...74425855346674
11 - Turn the boot inside out, and use a pair of alternative lifestyle cutters to remove the zip tie holding the shift knob retainer piece on
http://picasaweb.google.com/cpavlas/...74434445281282
12 - With the retainer piece removed, use a seam splitter, or other sharp cutting device, to cut the stitches out. You only have to snip a little but then pull the material apart. It comes apart quite easily
http://picasaweb.google.com/cpavlas/...74451625150514
13 - With the shift boot separated, you are now ready to make yourself the template for your new boot
http://picasaweb.google.com/cpavlas/...74455920117826
14 - Layout each half of the cars original shift boot onto the material of your choice and trace the pattern on to the new material
http://picasaweb.google.com/cpavlas/...74464510052434
15 - Cut out your pieces and then sew them together at the edges, just like the stock boot was
http://picasaweb.google.com/cpavlas/...74468805019746
16 - Re-attach the shift knob retainer and use a zip tie to hold it in place, just like the stock one was
http://picasaweb.google.com/cpavlas/...74485984888962
17 - Flip the boot back out again to prepare for attaching it to the shift boot assembly
http://picasaweb.google.com/cpavlas/...74490279856274
18 - Staple the new shift boot onto the assembly
http://picasaweb.google.com/cpavlas/...74498869790882
19 - Reverse your un-installation procedure from above and think to yourself, wow, this was the cheapest mod ever
http://picasaweb.google.com/cpavlas/...74503164758194
I went with white because I have a white/black leather seats combo going in, along with aluminum shift knobs etc. It wont look so out of place once thats done
- Scissors
^lol, thats exactly where i'm going to go too lol.. time to find REAL leather!
Wow just a zip tie??
No metal ring of anything else spiffy?
Anyway... good write up man!
Thanks guys. It will look better once the seats go in. Unfortunately, no one has patterns for the new seats yet, so they cant be done. What happened to the good ol' days when you made your own patterns?
You have to go to a leather dealer to get leather. If you want the stiching like above, its easy to do. Just choose your color and run it down with your sewing machine. Im not a big fan of the stitching though, so I didn't do it. I should update my pics with the new aluminum shift knob. It makes it look worlds better.
