Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
How to turn off Daytime Running Ligths
Old May 14, 2008 | 12:51 PM
  #31
Boricua_Evo's Avatar
all this for a simple DRL...
Old May 31, 2008 | 07:32 PM
  #32
edofloat's Avatar
Why would the owners manual tell you how to disable the DRL's???? If the manual tells you which fuse to pull I can't see how that voids anything. It is a fuse. Moreover, I suspect if you drive in to a dealer and they notice that and point it out it would be simple to tell them, yeah I pulled the fuse like the owners manual said. Done. Who cares?
Old Jun 13, 2008 | 08:43 AM
  #33
jd888jd's Avatar
Originally Posted by mksevo
ok, per the owners manual, you will need to access the fuse box in the engine bay, its the large black box on the drivers side. lift the lid from the front there is a small plastic latch. you will need to remove fuse # 13 this is the last fuse on the first row of fuses at the bottom of the box. it should be a red 10 AMP fuse. look on page 7-42 of the manual if you need a pic. but the bottom row of small fuses has only 13 in it. pull this out and presto no DRLs , I did test everything else and all seems to work fine. spaces for fuse 11 and 12 were empty. Hope this helps.
This doesnt work on Canadian Base model EVO X.....Tried it today..pulled the fuse out nothing happened. ..
Old Jun 13, 2008 | 01:55 PM
  #34
mksevo's Avatar
look in your owners manual , its the section on headlights and fuses. should show you which fuse runs the DRLs. they are on a seperate fuse link than the headlight.
PS this doesnt work for EVO without HID. so you may not have the HIDs.
Old Jun 27, 2008 | 05:48 AM
  #35
frankzz_x's Avatar
Did anybody find out how to disable the DLR for evo x non HID yet?
Old Jun 27, 2008 | 10:10 AM
  #36
dek0026's Avatar
Originally Posted by AkumaMax
just for the sure fact that some peoples eyes at night can't determine the distance of some cars. Your eyes sometimes plays tricks on you. Plus it's not just the fact that people have lights on then more or less it being a factor of falling asleep or being drunk etc... If you're that worried about the cops seeing you then you have got to slow it down a little. I know how the Texas highways are and everything but speed can kill! Also you don't own a sports car you own a 4 door Saloon
most cops don't even know what an evo is. to him it is another sedan and get and ticket and see what he write. most likely it will be mitsu lancer and the color. it isn't like you're driving a lambo. i hate when people think that their car is so cool that everybody wants to touch and cops are on the look out for it. give me a break!
rock on ricer!
i quoted because i am concurring with akumamax.
Old Jul 1, 2008 | 10:20 PM
  #37
whyb2nd's Avatar
you will loose the head lamp adjustment as well when you pull fuse #13 on an HID equipped GSR.
Old Jul 2, 2008 | 03:39 PM
  #38
mksevo's Avatar
My headlamp adjust switch works just fine. you can raise or lower the HID. not sure which model you have but you may want to check it again. or maybe you pulled the wrong fuse.
Old Jul 8, 2008 | 02:31 PM
  #39
SilverEvoX's Avatar
+1 I'm wanting to swap in some HID's but don't know how they will react with the half voltage running the DRL's normally...could you run with the headlights on all the time as a temp fix without disabling the DRL's? Thanks.
Old Jul 31, 2008 | 07:54 PM
  #40
CoEVOX's Avatar
+1
Old Aug 3, 2008 | 08:03 PM
  #41
evofan_08's Avatar
I run with them on all the time for now
Old Aug 3, 2008 | 09:20 PM
  #42
JayRoC's Avatar
Coming from a fourth generation eclipse... we had the same issue. The DRL's worked in conjunction with the low beams. However, a solution was found by tampering with some sort of circuitry box if you will. Not quite sure what it is, but it worked beautifully. Tried looking for something similar for the X but no luck. I'm no electrical engineer by any means, not my field... so I will attach a link to the how to on removing the DRL's on a 4G Eclipse with the same low beam issue. Perhaps it will help someone else figure it out... one day.
http://www.club4geclipse.com/modules...ewtopic&t=9913
For me, it has nothing to do with being spotted by cops, being more noticed, etc... it's the aesthetics. Personally, I think it takes away from the appearance of the car during daylight. For example, I'm sure many ppl here have shut their car off before taking a picture, just so they can get rid of the DRL for the shot.
As for the safety feature, I'm not trying to sound immature... but if you can't see a 2 ton 6 feet wide heap of metal heading towards you, then you really shouldn't be on the road, or crossing it. my 2 cents.
Old Aug 17, 2008 | 09:54 AM
  #43
itznoraa's Avatar
hm, so it can be done!
just needs someone to figure it out....
ill be waiting in the mean time
Old Aug 17, 2008 | 11:02 AM
  #44
415EVOX's Avatar
pull the light bulb out. isnt that the easiest way to stop the drl?
Old Aug 18, 2008 | 11:05 PM
  #45
hawaiian_evo's Avatar
nah wont work i know my gsr low beam bulb shares is the drl so pulling the bulb means no low beam haha. Stright high beam action in traffic guys would be flipping me off.
