Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Boost Gauge and MBC install
Old Dec 6, 2008 | 08:52 PM
  #61
_Chris_'s Avatar
Originally Posted by joeyhauser
So can someone tell me how exactly to install the MBC. ive heard too many different ways and i just want to be sure
http://www.zchip.net/showthread.php?t=16
I think this is the best way to do it.
Old Mar 6, 2009 | 01:00 PM
  #62
Bear.914's Avatar
you should of shown before and after pics to make it clear and kept it in one post its confusing
Old Jun 22, 2009 | 07:14 PM
  #63
Botticelli's Avatar
hey ... thanks for the guide and the pics... just wondering how much lbs of boost a stock engine can handle before stuff goes wrong... I just bought my X 3 weeks ago and am new to the scene.
thanks,
Matt
Buffalo, NY
Old Jun 22, 2009 | 07:22 PM
  #64
Blue_CobaltSS's Avatar
if im not mistaken its around 26lbs.
again im not 100%
Old Jul 20, 2009 | 02:06 PM
  #65
GTR THI5's Avatar
Best diagram I have seen on a MBC install.
http://turboxs.com/uploaded_images/522.pdf
Old Aug 24, 2009 | 05:47 AM
  #66
cnj4ever's Avatar
Originally Posted by Psquared
hey guys...just like the IX's. If you pull the cover off where the fuse block is under the left side of the drivers dash. The dimmer switch has multiple wires coming from the back of it. The green/white stripe wires is a dimmer wire. It's perfect to tap for illumination of gauges!
ok so if i use this wire for my Boost gauge, my Defi gauge wont be bright as the sun?? thanx for the help
Old May 3, 2011 | 07:56 PM
  #67
Bear.914's Avatar
Step By Step:
Step 1 : Locate your factory boost controller
Step 2 : Locate Wastegate/turbo outlet vacuum line and disconnect it from the port with the solid black hose
Step 3 : Now plug it into the wastegate port on your Manual Boost Controller
Step 4 : Disconnect the other vacuum line thats connected to the hose with white stripe/marking on it coming off your factory boost controller
Step 5 : Now plug that into the intake port on your Manual Boost Controller
Step 6 : Mount your Manual Boost Controller in a secure location
Old May 15, 2011 | 10:42 AM
  #68
ErnGotti's Avatar
One question....Why does everyone care about bypassing EBCS to install an MBC? Thats like disconnecting the driveshaft to make the car FWD. Its backwards. I strongly advise against using an MBC and either tuning the OEM EBCS's or getting the GrimmSpeed or GM 3-port EBC and install that and tune with that instead. All these cars need tunes anyways straight from Mitsu so if you wanna play with boost, go that route. The GM solenoid is ~$70.00.
Just a tip
Old Aug 22, 2011 | 04:09 PM
  #69
black rat's Avatar
I need this lol! will be doing this as soon as I get my boost bauge this week!
Old Sep 5, 2011 | 11:29 PM
  #70
iiburthd's Avatar
should be doing one myself soon!
Old Sep 5, 2011 | 11:30 PM
  #71
AzShawn's Avatar
Why would one go MBC over a ECU based controlled EBC and tune?
Jameson_IXMR
21
Dec 11, 2016 07:33 PM
khami
Sep 1, 2015 07:54 AM
TxFAkuma
Aug 9, 2015 08:01 PM
LakerRaider
13
Mar 26, 2011 08:13 PM
Gooseman396
Sep 22, 2010 09:23 AM
