Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Removal of Rear Subwoofer.
Old Apr 16, 2008 | 09:17 PM
syr00's Avatar
Ok... I see four wires, from what I understand is that there is two sets on for each voice coil... So giving that, how would you set up a line converter to RCA to be able to plug into the amp?
Old Apr 17, 2008 | 04:50 AM
mksevo's Avatar
You will use 2 for positive and 2 for neg. if you want mono subwoofer. if you have line inputs into your converter then you will use 1 set of wires for each channel R and L. then your sub is Stereo. if you have sub line out , then use the first method. the dual voice coils just help the sub work better and stay cooler. they are still just Neg and Pos terminals. hope this helps.
Old Jul 17, 2016 | 03:17 AM
EricSkiller's Avatar
Originally Posted by mksevo
Now remove you subwoofer, its not to bad about 10 lbs in wt.
is the wearing there if u have a stock sound system?
Old Jul 19, 2016 | 03:38 PM
jakeleclair2000's Avatar
Do you mean wiring? And no, wiring is only there on models equipped with the RF system.
salukidude
Feb 1, 2019 06:07 PM
salukidude
Jun 17, 2018 12:43 AM
Veronica
May 18, 2017 01:09 PM
Evo__Lee
Feb 20, 2017 08:05 PM
Built2Fast
Jul 29, 2016 07:40 AM
