Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Removal of Rear Subwoofer.
Old Feb 24, 2008 | 02:53 PM
mksevo's Avatar
this is as easy of a job as it gets. rate it 1/10 . First you will need a 10mm socket with short or medium extension and a phillips screwdriver. start at the top of the subwoofer and remove the 2 bolts 10mm heads. be careful as not to scratch the subwoofer face hence the need for an extension.
Old Feb 24, 2008 | 02:54 PM
mksevo's Avatar
Second remove the trunck carpet and cardboard support.
Old Feb 24, 2008 | 02:57 PM
mksevo's Avatar
thirdly you will need the screwdriver to remove the bolt holding down the styrofoam base .
Old Feb 24, 2008 | 02:58 PM
mksevo's Avatar
Fourth you will need the 10mm socket again to remove the last bottom bolts on the subwoofer box.
Old Feb 24, 2008 | 02:59 PM
mksevo's Avatar
then Remove the connector attached at the top of the subwoofer you will need to tilt it out slightly it has a push up clip on the bottom. try using the screw driver to push up the little clip.
Old Feb 24, 2008 | 03:00 PM
mksevo's Avatar
Now remove you subwoofer, its not to bad about 10 lbs in wt.
Old Feb 24, 2008 | 03:01 PM
mksevo's Avatar
here is the sub out of the car. your Done. I will post some pics of the internals tonight and see what my upgrade path is for better sound.
Attached Thumbnails Removal of Rear Subwoofer.-sub7.jpg   Removal of Rear Subwoofer.-sub8.jpg
Old Feb 24, 2008 | 03:58 PM
Sofla GTS's Avatar
you dont need to remove the cardboard its not in the way
Old Feb 24, 2008 | 04:12 PM
mksevo's Avatar
Subwoofer complete is 16 pounds on my scale. to remove it from the box, you will need to remove all the grill screws and then the large silver screw in the back center location. here is an open box pic.
Old Feb 24, 2008 | 04:19 PM
mksevo's Avatar
the speaker on the back says 1.1ohm 75w, made in china , who would have guess, mitsu
Old Feb 24, 2008 | 04:22 PM
mksevo's Avatar
I dont know how you will remove the styrofoam the card board sits on it. it not a must bu keeps the clutter down and gives you room to work .
Old Feb 26, 2008 | 06:06 PM
Noize's Avatar
EvoM Administrator
Thanks tons for all these writeups!
Old Feb 27, 2008 | 02:57 PM
Tunerhead's Avatar
Very good with good quality pics.
Old Mar 1, 2008 | 02:25 PM
PERRIN_Adam's Avatar
So where are the promised pics, etc. of the planned changes? I was relatively impressed with the OEM RF system but if you have an easy solution for even, more there would be no argument from me!
Old Mar 1, 2008 | 04:07 PM
mksevo's Avatar
there is another thread on subwoofer replacement. I dont have any info yet but Will post when i find a good sub or amp sub combo.
