Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
AMS Shift Bushings
Old Mar 15, 2008 | 04:47 PM
Talon_66's Avatar
AMS Shift Bushings
Has anyone installed these?
I must be a total idiot because I couldnt figure out how to get these installed... I fail at life
Old Mar 15, 2008 | 07:57 PM
EricJ@AMS's Avatar
Talon 66 what in particular are you having an issue with?
Old Mar 15, 2008 | 08:00 PM
Talon_66's Avatar
I cant seem to get the rubber/stock bushings out.
Old Mar 15, 2008 | 08:34 PM
Scottr126's Avatar
Did you get it figured out? The bushings should come out fairy easy with some pliars.
Old Mar 15, 2008 | 08:36 PM
Talon_66's Avatar
havent figured it out yet. I will give it another whack tomorrow. I feel like quite the genius I have been reading threads on bushing install on previous gen evos.
Old Mar 16, 2008 | 11:48 AM
Tim@AMSperformance's Avatar
simply push the small bushing out with a screwdriver. On the big bushing you may have to push the center plastic piece out first and then push the rubber part out secondly.
Old Mar 16, 2008 | 04:13 PM
Talon_66's Avatar
I got them in, but I bent the **** out of the pin holding the rear bushings in.
I used the pin, but I have no clue how it is supposed to go back on, but Im hoping it holds up...
Old Mar 16, 2008 | 04:16 PM
STi2EvoX's Avatar
Use a bushing press tool because you'll never get the old ones out with a screwdriver. I tried that and they won't budge at all. Just be careful not to stress the cable or bend it while trying to pop the old bushing out. Good luck. BTW talon, I'm EVOXGSR over on evox. When I mentioned that getting the old bushings out was a *****, I wasn't kidding, was I? Like I said, just use a press tool, like a portable vice grip, and compress the bushing itself, hold the loop of the cable and then twist the bushing diagonally through the hole and it should pop out. Good luck,
Old Mar 16, 2008 | 04:18 PM
STi2EvoX's Avatar
Whoops, I posted this before I saw your last post. Good luck with the pin.
Old Mar 16, 2008 | 04:21 PM
Talon_66's Avatar
I pushed mine out with needle nose pliers
Also, does anyone know what type of pin is used to hold the rear bushing?
I will buy a new one.
Old Mar 18, 2008 | 10:10 PM
R0ME0's Avatar
Did you get them on? We want a thorough writeup and review?
Old Mar 19, 2008 | 03:03 PM
Brahmzy's Avatar
Yes, please review the differences.
Old Mar 19, 2008 | 05:27 PM
Talon_66's Avatar
Noticeable difference in shifting. Definitely a better feel.
But I still have the 1st to 2nd problem
Old Mar 19, 2008 | 09:52 PM
R0ME0's Avatar
define better??
Old Mar 20, 2008 | 08:06 PM
Talon_66's Avatar
Better as in smoother shifts, more accurate/precise
