Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
IPOD on evo X
Old Jan 22, 2009 | 10:59 PM
dierr's Avatar
not on the ipod side.. where does the other end hook up to?
Old Jan 23, 2009 | 03:56 AM
aftershock141's Avatar
Looks good! I just bought the belkin cable from circuit city. I can't charge the ipod but oh well.
Old Jan 24, 2009 | 03:16 AM
JayDub514's Avatar
In front of your shifter, underneath your AC controls. There should be a plastic flap...open it up and you have your RCAs.
Old Apr 10, 2009 | 02:48 PM
AKhan83's Avatar
where did u order this part from? I've called 3 different mitsubishi dealers and they havent been able to help.
Old Apr 10, 2009 | 05:09 PM
AKhan83's Avatar
Where did u order part?
Originally Posted by typoist
I have had/seen quite a few questions about how to connect ipod to a evo x that doesn't have the SSS package. This is for all of those guys. As well for anyone in canada that owns a evo X as well, since i own an evo thats from canada. This mod will give you the video/audio box that is located in the rear of the center console.
this mod is quite easy.
first order the part from mitsu. Part # 85927
then take the dash apart and take your stereo out. See how to install nav in a non nav evo x if you don't know how https://www.evolutionm.net/forums/sh...d.php?t=324696
After the deck is out reach into the hole where the deck use to be. The connector you are looking for is connected to be back of the cubby hole. Unplug connector.
Now the next part can be easy or hard all depends on what you want to do. I removed the whole center console between the passanger and drivers seats. I did this so i can remove the cubby hole out of the car and bring it into the house. Or you could just cut out a hole on the spot.
here is a pick of how to remove the center console and the dash
1- 2 take out the cup holder. before you do that pull out the little holder... looks retangular and you can only put cell phone in there or ipod. It pulls out right out. be carefull there is a electrical connector hooked to the back of it. Disconect electrical connector and then pull cup holder out. Its a little hard to pull out but it pops right out.
3 turn out the shifter handel counter clockwise. i counted the amout of time it spun cause i like to have the exact tightness again when i put it back on. but you don't have to be **** like me.
4 take the 1 screw oput and then the shifter consol should pop out.
5 - 13 i beleve that there was only 5 screw holding #10 in. There is one that is connected to the middle of #10 and then there are 2 that are connected to #12 and the last 2 you have to open up the arm rest and they are at the bottom there. once you have those out it the whole center console comes out.
Once all that is done make sure that the 2 screws above the HVAC controls are removed and then the HVAC console should come right out. It took me QUITE a bit of force to pull it out. BE VERY CAREFUL when pulling it out there are 4 tabs. one at each corner. i didn't pull it out evenly and kinda bent the tabs a bit. was not really a problem i had to bend the plastic back when i had to put everything back together. Once it's out there are 4 screws at the back take those out. and now you can cut the box and fit the A/V box in. connect the cable that was connected to the back that you just cut out and have fun with your new MOD. Hope this helps.
im trying to find this part. so far i called 3 dealers and no luck. can anyone give me some info on obtainin this for my EVO that wud be a great help!!!
Old Apr 10, 2009 | 10:22 PM
Deepseadiver's Avatar
Just print that post, go to the dealer and show it to them and have them order it. It should not take that long for them to get it.
Old Apr 12, 2009 | 06:00 PM
AKhan83's Avatar
Thanks! I've ordered the part. I can finally get rid of the FM tuner and enjoy my Pod.
Old May 22, 2009 | 07:05 PM
Dimitri13's Avatar
Sorry for the month bump, but how long would you suggest the cable be? And where would the best place for the iPod be? I don't want to put it in the cup holder, and I'd prefer not to use anything to make it stick to the dash =/
Old Jun 11, 2009 | 02:45 AM
Scottyb's Avatar
Registered User
they have this at the mitsu dealership
Old Jun 12, 2009 | 02:03 PM
michiganevox's Avatar
RCA plugs for audio video
I have a 2008 MR without navigation that was purchased in theU.S. I pulled the little rectangluar plate out that is under the climate controls but ther is nothing there. I thought this is where I could access audio video RCA connector so I could use an adpter cable to play MP3/ipod through the AUX of the radio. Can someone help?
Old Jun 12, 2009 | 11:04 PM
Dimitri13's Avatar
"first order the part from mitsu. Part # 85927"
That's the part you missed I guess =\
Old Jun 12, 2009 | 11:39 PM
Fishstix's Avatar
Huh? I went to Bestbuy and looked for an aux cord with a red and white end, and behold! It works! It cost around $10 I think.
Old Apr 30, 2011 | 07:17 AM
IceCold98GSX's Avatar
I have the AUX inputs in the cubby hold already.I also have the MMCS but when I took apart the console, there was no wiring harness running from the inputs up to the deck! Any help with this would be wonderful.
Old Oct 23, 2011 | 12:08 PM
thiagobr03's Avatar
Hey guys i have the rca plugs and all and i boughtthe wire from radioshack with the white and red plug and the headphone going into my ipod, i plug it in and all but nothing comes out is there anythin that i have to set on the radio? Thanks guys
Old Oct 24, 2011 | 10:27 AM
ogarcEVO's Avatar
