Vaccum level for EVO X???
The only vehicles that show no vacuum at idle are diesels, because they have no throttle plates. It will vary on your altitude, but -18 <--> -23 sounds healthy.
It's likely you tapped a line that has a check valve only allowing pressure, no vac OR you have a serious vac leak OR your gauge is busted.
EDIT: Sorry missed your post identifying a broken gauge. G'luck on the replacement!
hi
Hello
So if I am showing a vac of -10 or -12 is that ok I checked it on my Cobb app?
I am running the beta stage 2 map for 2011 gsr and this is the vac I get don't know stock since the app is also my digital boost guage via. The tantrix cable.
Part list
k&n panel, Cobb turbo inlet tube, password jdm uicp, and invidia exh single out.
Part list
Hello
Part list
Part list
If you had cams, crazy cam timing, or crazy density-altitude differences than "norm" maybe it would be okay, but sounds like a leak. or crazy check valve issue.
Try connecting a gauge to a different location that is direct to the intake manifold and make sure there's no check valve/pill/etc in the way.
Had problems with an AEM guage where the 12v I tapped into did not calibrate correctly and it would not read vacuum. If it's a stepper motor based guage, it needs a second to calibrate before engine cranks. Wired to a stable 12v and the problem was gone, reads the correct 17-21 inches now.
Any way to talk you out of an MBC?
ImsoevoX, make sure you get a digital gauge and not a mechanical gauge. Something about mechanical gauges on the X, for some reason, I've seen a lot of them "reset" themselves everytime you start the car which is why it reads 0. I had a mechanical AEM boost gauge and switched to a digital AEM boost gauge...problem solved.
