Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Idles like crap!!!!
Old May 26, 2008 | 04:02 AM
ImsoevoX's Avatar
Idles like crap!!!!
My Cel constantly comes on and my car is idling like crap. I checked all the upper IC pipes everything is ok. I have taken it to the dealer four times, they "reflashed it" or so they say, and also did an ignition re-learn...I don't know what to do..maybe I should turn it over to the guys at AMS..its just gonna cost. Anybody with the same problem? LEMON LAW!!!!!!!!
Old May 26, 2008 | 04:12 AM
DonHugo's Avatar
sounds like a vacuum leak to me but I could be wrong- double check all hoses
Old May 26, 2008 | 02:59 PM
Mightygnu's Avatar
Give the car to AMS and be the first to build the 4B11
Old Jun 9, 2008 | 01:58 PM
This_Guy777's Avatar
Try another dealer if there is one in the area. Dont mod the car until the problem is fixed.
Old Jun 9, 2008 | 02:15 PM
goofygrin's Avatar
ya, I'd go back to stock, pull the battery cable for 30 minutes and see if that clears it up.
What else have you done to your car?
Old Jun 9, 2008 | 02:20 PM
SilverEvoX's Avatar
Is the car stock still? If not what mods? What code is it throwing when your CEL is on? If you are unsure if they actually flashed the car, go back there next time and make them check the car for updated flashes, you can stand there and watch the computer and see if it shows updates or not when they connect it to MEDIC. Is it just idling poorly from a cold start or all the time?
We need more information to help you...
~Trent
Old Jun 9, 2008 | 08:02 PM
starmax's Avatar
mine is still doing this (had the car 2 months, and have had reflash #1). I've had 4 CELs now, am going back to the dealer again on wed to see what they can do. my evo is completely stock BTW...
Old Jul 22, 2008 | 10:31 AM
BluesunsXIV's Avatar
mine only idles like crap bc of the short ram and AC on at the same time. Do you have a short ram on your car? If you do its cuz of the heat from the radiator. Some intakes come with a metal piece to try and block some of this hot air.
Old Feb 3, 2009 | 12:01 PM
EVO X/GSR's Avatar
Make sure if you are using an after market cold/ram air intake that the MAF (MASS AIR FLOW SENSOR) sensor has the required height flange like OEM.
I purchase an intake, installed it and the car ran like ^%@#!! Contacted the dealer of the product and filled him in with what was happening (same symptoms) and after a few weeks and redesign they found that the MAF sensor mounting flange on the intake pipe had inadequate spacing causing the CEL to lite up.
Old Feb 3, 2009 | 12:06 PM
ej257gd's Avatar
Check the line from the fuel pressure regulator to intake manifold. (mine poped out on a stock car)
Dealership couldn't figure out why my car was idling so rough. (I found it by accident)
Old Feb 3, 2009 | 10:44 PM
alex3dworld's Avatar
change oil a cople of times ask for mobil one always
use 93 octane
add some injector cleaner for sintetic oil
had that problem first month, now is gone
is like a just born baby, it need to fart and burp for a while
Old Feb 3, 2009 | 10:53 PM
rcantu's Avatar
sucks. hate issues w new cars like that.
Old Feb 4, 2009 | 05:03 AM
pltek's Avatar
i think that we can safely asume that the OP is allset since he has not made another post since may 26 2008
Old Mar 25, 2009 | 03:12 AM
EVOXTIMES's Avatar
I have crappy idle also but with no cel codes brought it for a reflash .... But now instead of just a crappy idle below 800 rpm it jumps to 1200 rpm and tries to level itself out. I hear the Cobb ap solves this problem but I haven't purchase it yet. Btw I've only had my x a week!
Old Mar 25, 2009 | 10:22 AM
Sievers's Avatar
Agreed
