Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
fogs with parking lights?
Old Sep 11, 2008 | 03:43 PM
sl0ev0's Avatar
So nobody has figured out/cared about figuring out how to run the fogs on without the headlights having to be on?! im picking up my x tomorrow and thats the first thing i wanna figure out how to do!
Old Sep 11, 2008 | 03:49 PM
switchblade906's Avatar
i havent been able to do it, but it really doesnt matter to me b/c i never have them on since they dont match the color of the HID headlights
Old Sep 11, 2008 | 03:58 PM
Aseller's Avatar
I have this. Very simple just run a switch to the fogs from the fuse box. Make sure to turn your fogs of though or they will stay on even if the car is off... Happens every now and then. Walk all the way down the parking lot at night then realize... S**T I left my da**n fogs on! Walk all the way back.
Old Sep 11, 2008 | 03:59 PM
Aseller's Avatar
I changed my fogs to red, daytimes to red, and corner lights, and corner blinkers to red looks pretty cool to rock them all on without the headlights.
Old Sep 11, 2008 | 05:00 PM
sl0ev0's Avatar
yea thats a simple way but i want a more legit way, so i dont have to worry about shutting them off with an aux switch. i want it to be the regular switch in parking light position(if possible)
Old Sep 11, 2008 | 05:18 PM
WWevoX's Avatar
Ive been waiting for someone to post this...
I like the idea of utilizing the stock fog switch as well.
There has to be a way, but I haven't really looked at the schematics for it and I'm hoping it might be controlled from the computer and not a circuit being completed when the headlights are turned on.
Old Sep 11, 2008 | 06:13 PM
gotrnet's Avatar
i figured out how to do this a while back but it is in the general section.
https://www.evolutionm.net/forums/sh...d.php?t=351303
Old Sep 12, 2008 | 08:58 AM
08EvoXGSR's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=248060
This is the link gotrnet is talking about...but it looks like it wont be much help. My $.02-pull the fogs and let the air get to the oil cooler and brakes better
Old Sep 12, 2008 | 09:14 AM
Hiboost's Avatar
Instead of powering them with 12v power straight from the fuse box, try using the power signal to the parking lights to the signal side of a 30 amp relay (assuming that is enough amp rating) and then run the 12v power to the supply side. Ground the relay and send the power output to the foglights.
That should trigger the flow of electricity to turn them on whenever the parking lights are on. You could even throw a switch in the relay circuit to deactivate it. As always make sure you use proper gauge wiring and appropriate fuses for safety.
Old Sep 12, 2008 | 09:31 AM
gotrnet's Avatar
i believe the one that 08evoxgsr posted is for the evo VIII and IX models (i very well could be wrong and even if it is for the VIII and IX's it doesn't mean it won't necessarily work for the x i personally have not tested it). there is a link off the thread i posted to a pdf with a few pictures and things. essentially you tap into the ground and ground it out yourself with a switch so you can control when they come on. i used a relay so that they couldn't be on when the car wasn't running but you could just as easily hook that relay to the parking lights and use them as the trigger.
Old Sep 12, 2008 | 09:57 AM
that would be the best bet with the parking lights, use the fog lights as your running lights.
Old Sep 16, 2008 | 03:51 AM
gotrnet's Avatar
has anyone else actually done this? just curious.
Old Sep 23, 2008 | 11:14 PM
toolapcfan's Avatar
If I had a PDF service manual for the X I could figure it out.
Old Sep 24, 2008 | 04:13 AM
gotrnet's Avatar
guess you didn't read over the thread i linked to. there is a link on that thread to a pdf showing pictures and wiring diagrams from the service manual. i modified the pdf with an explanation of things and how to. here is the link.http://webpages.charter.net/gotrnet/...glight_mod.pdf
Old Sep 24, 2008 | 04:24 PM
toolapcfan's Avatar
Very nice sir. I didn't have my contacts in and I couldn't read the screen worth a ****.
