Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
How to install coilover suspension?
Old Sep 19, 2008 | 04:27 PM
ZK's Avatar
ZK
Anyone with an how-to install suspension? Specifically the rear suspension. Does it require you remove the seats? What if you need to adjust the rear dampening? How do you reach the adjuster?
Old Sep 19, 2008 | 08:24 PM
tookinkee's Avatar
Pm me and I can explain in detail if you would like.
Old Sep 19, 2008 | 08:32 PM
goofygrin's Avatar
Evo-L posted a how to on it, but to answer your question, you have to remove the rear seat (pull the bottom off, then three bolts, then pull the seat back up then out) and all the plastic crap in the trunk.
To adjust the rears, you'll either get to take it all apart again or use an extender. Touge Factory sells extenders (but I'm not sure if they work on anything but Stance coilovers). I think Evo-L has them or includes them with BC coilovers. Evo-L talks about cutting the carpet to show them, but I can reach them through the battery and washer compartments without a problem.
Old Sep 24, 2008 | 09:48 AM
wongck's Avatar
I think there's a pretty comprehensive installation thread for BC coilovers somewhere in here...
Old Sep 24, 2008 | 02:21 PM
08EvoXGSR's Avatar
FYI-I got my BC's installed fine w/o removing the seats, and adj them by removing the rear trunk plastic only-no extensions (you have to 2 finger it, but I hear thats the way they like it )
Theres 3 bolts on the rear (cant miss them) and 5 on the fronts....I'm not even sure I needed (I did tho) to remove the abs bolt, ect.
Old Sep 24, 2008 | 03:22 PM
goofygrin's Avatar
You didn't need to remove the ABS bolts (on the rear I assume you're talking about, you obviously need to remove the brake line bracket on the front).
dipsetinallday
11
Apr 28, 2016 06:02 AM
gr8dc2b
Apr 28, 2014 07:08 AM
AndyCT9W
Nov 10, 2013 01:25 PM
hybrid_r
EvoX 'For Sale' Suspension / Brakes / Handling
11
Jan 15, 2012 02:53 PM
