how do i go about adjusting the rear suspension camber?
Old Jul 9, 2009, 05:11 PM
dipsetinallday's Avatar
how do I go about adjusting rear suspension camber?
Old Jul 9, 2009, 05:14 PM
Smike's Avatar
Location: somewhere testing various tires, brakes, and suspensions.
Via the rear camber selection...done at a shop.
Old Jul 9, 2009, 05:41 PM
where is the camber bolt and can it be set to zero camber
Old Jul 9, 2009, 05:42 PM
justboosted02's Avatar
with a camber gauge and a piece of string you can do your own alignment.
the rear camber eccentric bolt is on the lower control arm, if you change your camber you will change your toe also.
Old Jul 9, 2009, 06:21 PM
Smike's Avatar
There is more to it then that. If you don't know how to do it - DO NOT DO IT.
A shop will know how to adjust. And yes, it can be zero'd, but that wont handle well.
Old Jul 9, 2009, 10:39 PM
At most i'm thinking of leaving the whole car at -.5 camber. Because i have aggressive suspension that wants to eat up tires in thousands of miles, that are orginally suppose to last like 20,000+ miles.
Old Jul 10, 2009, 02:59 AM
Smike's Avatar
That is from toe. Zero the toe out. I run -1.7f and -1.5r, my Z1s have lasted over 20k and thats with a race season on them.
Old Jul 17, 2009, 06:47 PM
willitas34's Avatar
+1
Negative camber will slowly eat the inside of your tire over time, but the toe is the real culprit. It will cause feathered wear along your tire
Zero your toe out on your tie rods, if you know how. If not, take it to a shop
Old Apr 27, 2016, 04:30 PM
Bmurray's Avatar
I'm bringing this thread back as I just need to confirm... I thought only the fronts of these cars had factory camber adjustment??
What is the range of neg camber adjustment for the rear factory arms/bolts?
Old Apr 27, 2016, 06:05 PM
Received 1,384 Likes on 1,317 Posts
For sure the rears have camber adjustment. You can get at least -2 degrees but that is not recommended
Heres a couple of shots of the manual that might help
Old Apr 27, 2016, 08:05 PM
Bmurray's Avatar
You think I can have toe "in the green" with -1.8 camber?
Old Apr 28, 2016, 06:02 AM
Absolutely. Im at -1.8 at factory toe
goofygrin
88
Jul 24, 2022 08:22 PM
OX
Feb 28, 2017 06:32 AM
pd9000
Dec 15, 2016 09:53 AM
QCRVR
Outlander Sport
Oct 4, 2016 02:29 PM
ocase
Aug 5, 2016 01:22 PM
Quick Reply: how do i go about adjusting the rear suspension camber?
