E-brake Adjustable?
Old Apr 22, 2016 | 11:33 AM
[GBU]Moon's Avatar
E-brake Adjustable?
Seems like my e-brake has gotten pretty weak over the years. If I'm on any type of slanted surface, it's not 'grabby' enough to keep my car from rolling. Anyone know if the e-brake can be adjusted?
2003 Evolution VIII w/ 154,000 miles
Old Apr 22, 2016 | 11:37 AM
Epyon's Avatar
Typically there are adjustments under the center console where the cable connects to the handle. Although this is just experience from previous cars I have owned.
Old Apr 22, 2016 | 11:39 AM
Pal215's Avatar
Yup,
The E-brake handle has a nut on the bottom part of it that can be tighten to increase friction force on the rear drums. It's easiest to get to by unscrewing two philips head screws inside your center compartment and poping that off.
If it's already full tight, then you have to tighten the brakes by removing the rear rotors and adjusting a spring inside the drum. Odds are you don't have to do this.
Cable stretch is unavoidable and will happen over time.
-pal215
Old Apr 22, 2016 | 12:36 PM
LetsGetThisDone's Avatar
Originally Posted by Pal215
Yup,
-pal215
You don't have to remove the rotors. There is a rubber plug on the wheel mount surface of the rotor, you pop it out and it gives you access to the star wheel to adjust the shoes.
Old Apr 22, 2016 | 02:10 PM
Pal215's Avatar
I had no idea, that's a nifty little trick they put in there!
-pal215
Old Apr 26, 2016 | 09:55 AM
GTijoejoe's Avatar
-pal215
Once you are past adjustment of the shoes from the rotor side and past adjustment from the lever side in the center console, you need to replace the cables typically.
First adjustment is lever side (minor)
Second adjustment is rotor side (major)
Careful on the major adjustment because it can make the brake shoes drag.
FYI
Old Apr 26, 2016 | 10:40 AM
The shoe adjustment should really only be a one time thing everytime you replace the rotor, or if the shoes get replaced. The shoes shouldn't wear because they just hold the car in place. Only adjustment you should ever really need to do IF the shoes are correctly adjusted is at the ebrake handle.
Old Apr 26, 2016 | 10:58 AM
kyoo's Avatar
can adjusting via that method mess up the brake bias from left to right, if you don't do it exactly? sounds like adjusting the nut at the e-brake would be much simpler
Old Apr 26, 2016 | 11:01 AM
It's the ebrake, it really doesn't matter. You adjust until they drag ever so slightly. The adjustment at the shoes is the shoe adjustment. The adjustment at the handle is the cable adjustment. One does not replace the other. They both serve an independent purpose.
Old Apr 27, 2016 | 07:29 PM
M4Lki3r's Avatar
Veteran: Marine Corps
The parking brake does not attach to the same brakes that your pedal uses. The parking brake activates a drum-style brake inside the rear rotors that holds the car in place. The pedal squeezes the rear calipers around on the outside of the rotors. Two different systems.
If you want to test it out, put the parking brake on, pull a rear tire off and remove the caliper. Try and remove the rotor. You probably wont be able to as the friction from the parking brake is holding the rotor still from the inside. How do I know this? I've done it and was scratching my head why I couldn't pull it off!
Old Apr 27, 2016 | 07:53 PM
barneyb's Avatar
I think Mitsubishi bought shoes for the drum brakes from Pep Boys. Some emergency brake, it can barely hold my car in place on my nearly flat driveway. My 1992 DSM had an emergency brake that locked the wheels like they were welded. Progress.
Old Apr 29, 2016 | 06:23 AM
GTijoejoe's Avatar
I think your system needs an adjustment, by regulation they require the vehicle at GVWR holds 20% grade pointing both up and down hill.
RallySport Direct
EvoX 'For Sale' Suspension / Brakes / Handling
Aug 28, 2014 05:11 PM
bnr34rb26dett
Aug 9, 2013 04:43 PM
funks
11
Dec 11, 2008 10:39 AM
DaWorstPlaya
Oct 21, 2008 09:47 AM
