Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
HKS type 1 tubro timer
Old Nov 19, 2008 | 04:24 PM
jk68x3's Avatar
I just purchased and hks timer. im not sure how 2 even install it and i cant read Japanese. HELP!!!!!!
Old Nov 19, 2008 | 04:50 PM
ilive2win's Avatar
did u get this one with the harness?
Old Nov 19, 2008 | 05:44 PM
jk68x3's Avatar
no i just ordered the harness. should have that in a week or so.
Old Nov 19, 2008 | 06:00 PM
ilive2win's Avatar
wellthe harness connects to the wires in your seering coloumn which comes off by ( i think its 3) screws. thre is a wire that on the left side, its the last connector, thatswhere your harness plugs into, then you have to pull your center console out to reach the e-brake wire (i believe its the green one) but there is only one, and use the red splicer to splice into the wire from the tt to the e-brake wire, make sure u squeeze the splice hard to get a good connection, then you just mountit to where ever you want , i used 3m red double sided tape, its really strong and holds well
hope this helped
Old Nov 19, 2008 | 06:01 PM
ilive2win's Avatar
and remember you cant lock your doors while the car is running, trying to find a fix for that
Old Nov 20, 2008 | 04:02 PM
jk68x3's Avatar
i tested that 2day and i will just lock them from the inside if need be(that still works) and once the car is off it should open with the remote but if not then i will just use the key
Old Feb 16, 2009 | 07:21 AM
andrealltrac's Avatar
jk68x3 did you connect the speed and rpm lead wire to it? I have the type-1 also and would like to use it to its full potential, I have been looking for hepl for a quite a while now!
Old Nov 23, 2009 | 12:11 PM
_Chris_'s Avatar
Originally Posted by andrealltrac
jk68x3 did you connect the speed and rpm lead wire to it? I have the type-1 also and would like to use it to its full potential, i have been looking for hepl for a quite a while now!
+1
Old Nov 23, 2009 | 01:02 PM
Evolutionary1's Avatar
Yes I to have been searching for the how-to on installing this timer and using it to its full potential. I have it installed in the ash tray area (fits perfect). Anyone find where to install the RPM and Speedo wires post up.
Old Nov 23, 2009 | 02:12 PM
I will try to post a how to in the next 24hrs for you guys, I got mine working just fine
Old Nov 23, 2009 | 02:47 PM
Keep me posted, PM me even I've had mine a year and not used it to its full ability yet.
Old Nov 23, 2009 | 04:29 PM
iSpooledYou's Avatar
is it true you have to leave a key in the car or something in order for it to work? i read it somewhere saying you had to... and don't want to do that.
Old Nov 23, 2009 | 04:38 PM
08EVOVA's Avatar
No you dont have to leave the key in the car for it to work. I just had this turbo timer installed in my car less than a week ago.
Old Nov 23, 2009 | 04:39 PM
mitsuevo803's Avatar
okay so how about the vehicle speed sensor. if you use pin 2 or 3 (injector 1 and 2) on the ecu, the RPM will work if you calibrate it, but anyone know how to hook up for the speed sensor?
Old Nov 23, 2009 | 05:16 PM
minievo82's Avatar
Wish I would have ran across this thread a while ago. It would have saved me a lot of time and pain in the ***. Not beging able to read japanese and not having any directions with it, made for a lot of fun.
