Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
How To: 5-Speed Transmission & Transfer Case Fluid Change
Old Apr 22, 2009 | 03:20 PM
Thegame's Avatar
It's the ACD system that needs bled, which is a different fluid than the transfer case. I think that stuff is just power steering fluid.
Old Jun 3, 2009 | 05:43 AM
Djstorm100's Avatar
anyone know for sure?
Old Jun 3, 2009 | 07:30 AM
LaXGSR's Avatar
ACD uses Diamond ATF (automatic transmission fluid). I don't think the system needs to be bled for a normal fluid change because you actually only drain the fluid from the rear differential AYC torque transfer mechansism (about 0.55 quarts). I don't think there is a procedure to drain the whole ACD system (which uses 7 quarts ATF). Maybe you only drain the whole system if you replace the ACD?
Old Jun 3, 2009 | 08:25 AM
empirepb210's Avatar
so basically this guide is useless?
Old Jun 9, 2009 | 06:46 PM
Djstorm100's Avatar
so just change the fluid like you would if you were changing the oil in the motor? No need to bleed the system?
Old Jul 16, 2009 | 12:56 PM
Evolution10GSR's Avatar
Bump. Anyone has any ideas. Local dealer charges $175 just for the transfer case fluid exchange.
Old Jul 16, 2009 | 02:57 PM
LaXGSR's Avatar
This guide is correct, and you can change the fluid just like you would change your oil. It should not be necessary to bleed the system if you are just replacing fluids.
Old Jul 22, 2009 | 11:48 AM
There is no bleeding involved when changing the transfer case fluid. I have asked a Mitsubishi Tech, the tech replied the bleeding is for the ACD. It's a simple DIY when changing the gear oil.
Old Jul 27, 2009 | 07:05 AM
AWDTerror's Avatar
what fluid is everyone using
Old Jul 27, 2009 | 09:38 AM
I used Amsoil for the tranny, for transfer case and rear differential, I used the Diaqueen for Mitusbishi.
Old Jul 27, 2009 | 09:53 AM
AWDTerror's Avatar
75w-90 gl5?
Old Jul 27, 2009 | 10:14 AM
stokEd's Avatar
Transmission: AMSOIL MTG 75W-90 (MTL 75W-80 can also be used)
Transfer Case: AMSOIL SVG 75W-90
Rear Differential: AMSOIL SVG 75W-90
Old Jul 27, 2009 | 08:33 PM
wtam1100's Avatar
This might help I got these part numbers:
TRANSFER CASE DRAIN GASKET 3200A102
TRANSFER CASE FILL GASKET MF660036 x2
TRANSMISSION PLUG GASKET MD000312
Old Aug 22, 2009 | 11:27 AM
_Chris_'s Avatar
Do you guys prefer AMSOIL over OEM Fluids?
Old Aug 24, 2009 | 01:36 AM
awdboostftw's Avatar
Originally Posted by iriejigga
thanks good info
+1
