Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Agency Power shorty antenna
Old Jun 26, 2009 | 12:54 PM
Fishstix's Avatar
http://www.vividracing.com/catalog/a...8-p-46204.html
I just got this delivered, but it's not fitting. I have navigation... does that make a difference?
Old Jun 26, 2009 | 01:00 PM
tokeone's Avatar
damn, i ordered the same thing.. it says nothing about there being a difference (although i was told the apr vortex generator they carry would fit also, and it doesnt, plus it blocks the nav antenna from working...)
ill let you know monday if mine works
Old Jun 26, 2009 | 01:06 PM
Fishstix's Avatar
The APR VG doesn't fit? I just ordered that and the person I talked to said that it does.
WTF?
Old Jun 26, 2009 | 01:18 PM
Fishstix's Avatar
I tried again and it definitely does not fit.
Old Jun 26, 2009 | 01:32 PM
Fishstix's Avatar
Nevermind. You just have to take the screw out, screw it into the hole in the car, and then screw on the antenna.
Old Jun 26, 2009 | 02:14 PM
tokeone's Avatar
ill keep that in mind
as for the vg. i placed it on, everything seemed cool. when i tacked it down (from the front to the back, as stated in the instructions) the front part around the antenna popped up, i practically layed on it for 5 minutes, with no luck.
so after giving up, i jumped in the car to go to work, no sirius. it just kept cutting in and out like i was going under an overpass/trees.
Old Jun 27, 2009 | 11:03 AM
freshpl's Avatar
post pix when u guys get a chance!
Old Jun 27, 2009 | 12:08 PM
monkey_187's Avatar
I would also lie to see pictures if anyone has them, I was thinking of getting the same antenna but now Im not sure I want to.
Old Jun 27, 2009 | 12:16 PM
Fishstix's Avatar
Old Jun 27, 2009 | 12:18 PM
Fishstix's Avatar
Old Jun 28, 2009 | 09:12 AM
freshpl's Avatar
was about to purchase but :
Next Day Air Early AM $95.69
Next Day Air $64.38
Next Day Air Saver $59.43
2nd Day Air $35.79
3 Day Select $27.21
Ground $17.47
anyone know where I can purchase where shipping isn't as much as the antenna almost
Old Jun 28, 2009 | 09:50 AM
JoeyM3's Avatar
lol that gap is horrible, go with the perrin one, no gap. and the vg does not stop the nav from working, the nav antenna isn't even on the antenna base it's under the dash lol. . . .
shoulda just taken your sisters wrx antenna, it would probably have fit better
Old Jun 28, 2009 | 10:12 AM
tokeone's Avatar
joeym3 - sirius stopped working and the nav screen and directions were refreshing almost as if it were on a dial up modem.
cut the piece off... and all is well. so the base of the antenna 100% effects both things.
Old Jun 28, 2009 | 10:42 AM
JoeyM3's Avatar
lol i've had this piece for probably 4 months and i have not had any problems with my nav, the nav antenna is on the actual nav so i don't understand how this would affect the nav at all, no reason for there to be 2 antennas. check antics22 nav install, nowhere does he replace the antenna base. i don't listen to sirius so i can't comment on that. but my nav works perfectly fine, it doesn't make sense that a piece of cf will block a signal when metal has no affect.
Old Jun 28, 2009 | 11:07 AM
Fishstix's Avatar
I don't mind the gap. It doesn't really bother me.
