Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Interior Rattle
Old Jun 30, 2009 | 03:07 PM
boobcakes's Avatar
Interior Rattle
Anybody care to write up a "How to get rid of Interior rattle" ?
I've got about 5 rattles now all coming from the dash area. I know I'm not alone, and I hope there is a way to fix it. All ideas welcome.
Old Jun 30, 2009 | 05:38 PM
jmorris1027's Avatar
punch it. or you could find where its rattling from and put some felt tape between the plastics..
Old Jun 30, 2009 | 06:34 PM
Mark B's Avatar
Some where there is a (how to) to take the front panels out to do the nav system this should get you started . Mine rattles at the face plate of the radio ,I took care of the glove box by adding 2 (vinyl pad bumpers Clear 5/16 diameter ) From Ace hardware to the glove box where it contacts the rubber grommets tightens it right- up worked great .
Also get under the car and check your rocker panel inserts ,they emmit a load of rattles loosen the screws and insert some porous foam ( to let moisture out ) to tighten them -up also .
Old Jun 30, 2009 | 09:02 PM
EmperorX's Avatar
Do you have solid motor mounts or somthing?
Old Jul 13, 2009 | 11:56 PM
08 Evo X MR's Avatar
my glove box is the only thing that rattles, it rattles where the clip that holds it up is so i dont kno what to put their while still being able to close it
Old Jul 14, 2009 | 12:25 AM
BobcatGTS's Avatar
Forgive me for being the newb and not owning an X, but I thought I'd share this... I got my instrument cluster bezel replaced under warranty because it rattled, but there are still others.
Most noticeably on bumpy roads. It's just bound to happen with our cars. Mitsu cut costs when it came to vibration and sound dampening, but they are realizing their mistakes now, as evident in the new soundproof windsheild glass for the 2010 models.
Old Jul 14, 2009 | 02:03 AM
EndlessRed's Avatar
hadoken your entire front dash. problem solved.
Old Jul 19, 2009 | 12:57 PM
blueberryyumyum's Avatar
Yeah I'm getting some rattle in my dash well.. Thread subscribed!
Old Jul 20, 2009 | 09:39 PM
Finest's Avatar
I did just that and it took care of the problem.
Old Jul 30, 2009 | 04:37 PM
boobcakes's Avatar
after a few more weeks of driving around, I've noticed a pattern. When it's really hot outside, it's fine. Colder days, it's down right annoying. It kinda sounds like maybe some of the tape under the dash that holds wires? It's pretty suck-tastic.
Old Jul 30, 2009 | 04:41 PM
Capone X's Avatar
haha
HAAAA DOOOO KEEEEENNNNN
Old Jul 30, 2009 | 04:43 PM
Capone X's Avatar
Lets Kamehameha it also
Old Jul 30, 2009 | 08:45 PM
ILowNslowI's Avatar
seems to be a common issue with these cars...mines the same thing!
Old Jul 31, 2009 | 07:23 AM
twistyking's Avatar
I had 2 dash rattles that were pretty darned annoying but seem to be pretty common. I've fixed the ones on my car with minimal effort. Granted my car is stock
so no loud exhaust, motor mount or lowered suspension causes.
1. "Windshield" rattle. In the middle of the dash next to the windshield there is a small rectangular "box". This was real loose, enough to send a rattle noise echoing against the glass. I just put a small piece of tape on it and that sound is gone.
2. "Instrument Cluster" rattle. Mine was not anything to do with the cluster but sure sounded like it. The housing for the steering wheel shaft was the culprit. I wedged a piece of insulation between the housing and where it meets the under side of the dash. Problem solved.
Hope this helps.
Old Jul 31, 2009 | 07:27 AM
Sharkbite2000's Avatar
Patiance my friend you track them down 1 by 1 and solve it took me awhile and now mine rattle's just fine
