Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Brake Oil Bleeding
Old Sep 16, 2009 | 07:57 AM
CatalystGod's Avatar
Originally Posted by MrBonus
I highly recommend getting a power bleeder and saving yourself the headache of having to do the two-man brake pumping routine.
I'll look into it, thank you for the input.
Old Sep 16, 2009 | 08:02 AM
Originally Posted by mad_VIII
BTW man, it's not OIL it is fluid. And if you have never bled brakes before you need to find a general how-to for BRAKE FLUID BLEEDING or BLEEDING BRAKES, it sounds like you may still be a little confused about the sequence of events that need to take place to force the old FLUID out of the system.
Like I said, I'm fine with about 80% of the sequence of steps. The remainder 20% that I am asking here about really are about the fluid mixing issues and if there is anything special we need to do that is not mentioned inthat article I posted. Thank you for correcting me on the Oil/Fluid thing BTW.
Old Sep 16, 2009 | 08:58 AM
LaXGSR's Avatar
Originally Posted by CatalystGod
The article I posted in my first post actually has the order in it with a schematic. I intend on following it, unless someone's gonna tell me it has changed for the X.
The order that migs647 posted is different than the article. It's very likely the older is different for the Evo 8 vs 10. I would check the factory service manual to be sure.
Old Sep 16, 2009 | 09:06 AM
migs647's Avatar
Actually I posted the wrong order . That is the article I used when I did my job about 5 months ago. Had it in memory wrong . Corrected my post.
Bleed order
1. Passenger's side rear outside nipple
2. Passenger's side rear inside nipple
3. Driver's side front outside nipple
4. Driver's side front inside nipple
5. Driver's side rear outside nipple
6. Driver's side rear inside nipple
7. Passenger's side front outside nipple
8. Passenger's side front inside nipple
Old Sep 16, 2009 | 10:23 AM
atombomb33's Avatar
EvoM Community Team
Glad to hear that you took my previous post exactly the way I intended. Just looking out for a fellow Evo dude
To your question about mixing fluids, don't worry about it. It's best if you can get an automatic brake bleeder or have someone help you. You'll begin bleeding the brakes (in the order posted) and as soon as the reservoir is low, then you begin adding fluid...and then just continue adding it until you're all done. That's really the best you can do. Good luck
Old Sep 16, 2009 | 10:31 AM
^^ Yeah, that's exactly what that article had, I'll double check with the manual anyway just in case.
Old Sep 16, 2009 | 12:24 PM
That's what I was thinking. Thank you for confirming.
Old Sep 28, 2009 | 07:58 PM
LaXGSR's Avatar
Bleed order
I just checked the evo x service manual, and the order is DIFFERENT than previous evos. The evo x order should be driver rear, passenger front, passenger rear, driver front. So basically the driver and passenger sides are switched. For each corner, you still bleed the outer nipple and then the inner nipple.
Old Sep 29, 2009 | 08:12 AM
Thank you.
Old Jan 24, 2010 | 10:14 AM
henryDgreat's Avatar
thanks for the guide
Evoivnz
Oct 7, 2015 12:44 PM
Talon
11
Feb 24, 2014 05:38 AM
_hyper
15
Feb 16, 2014 08:12 PM
matrho2792
19
Feb 25, 2013 09:03 AM
Joe250
58
Apr 10, 2011 04:07 PM
